Old 05-07-2012, 03:20 PM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Cutter alternator charging alarm
I replace my alternator because an intermittent problem,but now i have a red alarm and the meter indicate no charge
Cutter 35' 99
I need electric wiring
landmarc is offline   Reply With Quote
Old 05-07-2012, 04:04 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Is the replacement a remanufactured or new unit?
What was the intermittent problem, no start, red light, low voltage?
Inspect battery, alternator and starter wiring for corrosion, loose connections and continuity.
It's possible the replacement alternator has a bad diode pac/open circuit.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-08-2012, 04:32 PM   #3
Rimouski , Quebec
Ifound the problem,that a open wire from the lamp alarm ,the alternator need this 12v to work
Tanks all
