Old 07-08-2012, 04:58 PM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Cutter 99 blower fan
i smelt smoke and the 4 position on my blower fan is not working,
Marc
landmarc is offline   Reply With Quote
Old 07-08-2012, 07:12 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Did you have the fan running already? or had you just turned it on?
The fan may be drawing to heavy for the switch control to handle if it is not on a relay.
I think your controls are different than that on the Clipper, but this may help.
http://www.airforums.com/forums/f313...ml#post1169912
If you could smell smoke in the cabin, chances are it is not the resistor which controls the lower speeds and is located on the front outside firewall on my Clipper.
Probably either the wiring at the switch or motor.
Dave
Marc
Old 07-14-2012, 03:39 PM   #3
Rimouski , Quebec
Dave
i found the trouble ,it's my fuse holder in the front outside who burned
Thanks so much,you are fantastic
Marc
Old 07-14-2012, 03:51 PM   #4
masseyfarm's Avatar
Images: 56
Its always nice when you find the problem and can get at it.
I updated my same fuse holder to one with a cover, to protect it a bit from the weather.
That fuse holder you have is available on line, and is expandable, but with no cover, I recommend just changing it to a protected style.
The other thing that you need to explore, is why it is drawing that much power? Have you changed the blower fan, as if it is at end of life, it may be drawing too much juice.
The other option, is to install another relay.
Dave
Marc
Old 07-14-2012, 05:01 PM   #5
Rimouski , Quebec
Yes a changed my motor,becaused it's was very noisy,i dont know if it's the problem but on the fuse panel there 2 empty connections and i put a ATC Fuses,add a circuit in line and my fan work in 4 position,i will try on the road because i am in a campgroud in NH for a week
Old 07-15-2012, 05:28 AM   #6
bnsonger47's Avatar
2000 36' Land Yacht XC Diesel
Louisville , Kentucky
Send a message via Skype™ to bnsonger47
Interesting discussion. My fourth position just doesn't work. The first three all function properly. I hadn't worried about it until reading this post. Now I'm wondering about the problem.
Byron Songer
2000 Airstream Land Yacht XC
Freightliner/Caterpillar
bnsonger47 is offline   Reply With Quote
Old 07-15-2012, 09:48 AM   #7
masseyfarm's Avatar
Images: 56
I might clarify that this fuse holder, on the Clipper, is somewhat exposed to the elements as it is mounted on the front outside bulkhead. This is why I recommend a cover for protection.
Later models I believe, have it mounted in the front ds compartment? and it should be weather protected there.
Dave
Old 07-16-2012, 07:55 PM   #8
Rimouski , Quebec
I put a clamp cd current on the circuit and a mesure 12 a I suppose it's normal in 4 position
