Old 05-13-2012, 09:03 PM   #1
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Clipper, Kwikee, Land Yacht
This applies to the Clipper, but other models may have the same step.
I have been having intermittent problems with my step not operating as/when it should. I had purchased a new motor some time ago and decided to install it for this travel season.
Replacing the motor is not a big job with only 3 mounting bolts to undo and the wire harness to be separated.
Gently wiggle and pry the old motor away from the gear face. Clean the gear face and lubricate before installing the new motor.
On the CLIPPER the KWIKEE step is a "series 42" and it takes the standard motor. (series 23 triple step requires the high torque motor)
The motor that fits "series 42" is "Dorman 742-206" for the 95-86 Taurus, Sable, 93-88 Continental. Drivers window lift motor. SKU 1330206-E6DZ5423394A-742-206-TAURUS-2
http://www.dormanproducts.com/catalo...LiftMotors.pdf
Page 5 of 20 shows the picture.
When reinstalling the motor, be sure to use some anti-seize on the threads so that it will be easy to remove the next time.
However, after finishing the installation, I still had the same problem. I tested the old motor and it seemed to be OK when tested with no load. So I had to troubleshoot further to find the problem. I discovered the main 4 position power plug had deteriorated and good contact was not being made.
Rather than replace the plug, I just cut it out and butt connected the wiring and heat shrinked the joints.
Problem solved.
Dave
ID:	158281   Click image for larger version
ID:	158283   Click image for larger version
Old 05-14-2012, 06:16 AM   #2
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
Nice work Dave, thanks for the write-up.
BarnacleBill is offline   Reply With Quote
Old 05-14-2012, 08:31 AM   #3
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
I just replaced with the same motor, but all my gearing is enclosed in the housing. Question is why do all the dealers for Kwickee steps tell us there are no replacement motors, you have to buy a complete assembly (only frame and steps can be salvaged) for approximately $360? Not very helpful!
raveson is offline   Reply With Quote
Old 05-15-2012, 05:23 PM   #4
masseyfarm's Avatar
Images: 56
Mud Flaps
Installed new grooved mud flaps on the front of the Clipper today to try to keep the spray down the side under control. Any improvement will be good. I am always washing the body below the rub rail. This may help control the dirt getting back to the Kwikee step also. While working on the steps, I cleaned a couple handfulls of gravel from the top of the step mount.
Dave
ID:	158499   Click image for larger version
Old 05-23-2012, 05:56 AM   #5
bnsonger47's Avatar
2000 36' Land Yacht XC Diesel
Louisville , Kentucky
Send a message via Skype™ to bnsonger47
You have to listen to what they are saying. There are no replacement motors from Kwickee designed for that purpose. There is more money in selling a complete assembly than in selling replacement parts. Also, fewer stock keeping units so it simplifies investing in parts as well as inventory.
Byron Songer
2000 Airstream Land Yacht XC
Freightliner/Caterpillar
bnsonger47 is offline   Reply With Quote
Old 05-23-2012, 10:51 AM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Technician time to install complete unit probably less than just the motor, when I did the motor it was from China, gears were slightly different than the original, I was able to swap gears and put it back together only using the new motor and old gears. My original problem was cast with ss shaft of motor binding due to corrosion, so if you can keep the weather off yours should last longer, while I had it apart it was apparent motor was made for a dry area, like inside a door with plastic protecting.
Old 05-23-2012, 12:51 PM   #7
345bill's Avatar
Las Vegas , Nevada
Yep, My first thought when looking at Dave's pic's in post # 1 was 'that sure looks the same as an electric window motor inside the door of an automobile that I had to change out a while ago'.
345bill is offline   Reply With Quote
Old 05-24-2012, 11:30 AM   #8
1998 35' Cutter Diesel Bus w/slide
Laud by the sea , Florida
laptop/utility table
thats a fantastic idea, i will implement as soon as i get past this never ending maintenance list...this will be a perpetual project !
mfancher is offline   Reply With Quote
