Old 10-22-2012, 03:58 PM   #1
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Clipper, Freightliner Chassis, Cummins, Allison, Notes
Air filter on a Clipper equipped with Cummins 8.3 s/b
# Dia Length Out In
114880003 9.75 16.9 5 6
Air Flow lbs kg
600 760 900 9.0 4.1
OEM: Farr (AUS) 114880-003 Cross to PA3493Baldwin Filters
Replacement for Ecolite Air Element in Disposable Housing Get Sale
Dave
Old 11-22-2012, 10:59 PM   #2
masseyfarm's Avatar
Images: 56
Weights, GVWR, Dry Weight, Hitch Weight, Hitch Ball Hight.
I will enter this informational document here just so I can find it in the future, as this stuff tends to disappear from the net.
I think I did post this on the trailer thread at one time, but I was not able to find it when I was looking.
This document lists the weights of all Airstreams products 'EXCEPT THE CLIPPER'.
http://airstreamlife.com/wp-content/...am-weights.pdf
Some of you may want to post it in another thread for general information.
Dave
Old 11-23-2012, 12:50 AM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Dave they may have missed the Clipper but they also seemed to have forgotten all of the Argosy and Classic Motorhomes.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 11-23-2012, 10:04 AM   #4
masseyfarm's Avatar
Images: 56
At the bottom of the document mentioned above is a rather important detail if you are looking for a used Class A in the 39' category which was on the XL raised rail chassis. Units prior to this s/n only had 36000 lbs GVWR but in 2003 the chassis was upgraded to 41000 lbs.
*Due to chassis upgrade, units before S/N 810839 in the 2003 model year 390XL have GVWR of 36,000 lbs.
Dave
Old 12-24-2012, 01:38 PM   #5
masseyfarm's Avatar
Images: 56
Clipper Owners Manual
This document has not been available on line so I will post it here for future reference. Airstream has only posted documents back to 1998 and I suggest you print off any that are of interest as they tend to disappear when server systems are upgraded.
I am unable to post the various schematics but if someone wants specific pages of those, I can photocopy and mail them for minimum costs.
The LAND YACHT CLIPPER was an ongoing project and probably few were of the exact same specs. This document applies specifically to #10137 but some of the information is general in nature.
There is a restriction on size of document upload so I will try to upload it in two sections.
Looks like I am unable to upload this, so if anyone needs it, I can email a copy.
Dave
Old 04-12-2013, 02:26 PM   #6
masseyfarm's Avatar
Images: 56
Clipper Wiper Re-fill
On the Clipper, Airstream used a 28" pantograph wiper with the 'wide base' bolt on blade assembly.
These assemblies used to be quite reasonable to purchase, but not anymore. The prices have got beyond the $30.00 with some quotes above $50.00 just for blade replacement. (mostly used by RV'rs so why not charge what the market will bear?)
Not many outlets carry refills for wiper blades anymore. However, RockAuto still has some old stock of the TR-71280 refills for the TRICO 67 Series blade. If your metal wiper assemblies are still in good shape, the refills are all you need. Always good to carry a spare, as traveling in remote areas you will find auto outlets give little chance of sourcing a 28" blade on short notice.
The blades usually fail after that hot spell and then the first rain, when the blade disintegrates where it is stuck at the bottom of the windshield.
This is the blade info below. the refills for these are eg: 71-280 (28")
The blades are wide saddle and bolt mounted.
67 Series - For Curved Windshields (Wide Saddle)
Trico's 67 Series heavy duty blades are designed for wide saddle
wiper arms, which are typically found on Class A recreational
vehicles, school buses, transit buses and heavy duty trucks. 67
Series blades are refillable with Trico's 71 Series heavy duty refills.
Part No. Length Finish Anco #
67-241
24" Black 52-24
67-261
26" Black 52-26
67-281 28" Black 52-28
Below is the TruVision equivalent.
http://www.dieselequipment.com/files...13AppGuide.pdf
AIRSTREAM
A-Series 2005 Class A TV6-28 TV6-28
Airstream 350 1990 Class A TV5-20 TV5-20
Cutter Bus 96-00 Class A TV6-28 TV6-28
Land Yacht 90-05 Class A TV6-28 TV6-28
Legacy 92-95 Class A TV6-28 TV6-28
Sky Deck 03-05 Class A TV6-26 TV6-26
All 75-90 Class A TV5-20 TV5-20
Dave
ID:	183069   Click image for larger version
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
