Old 07-15-2011, 02:29 PM   #1
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Clipper, Cutter, Land Yacht, Interior Updates
Coffee and drink holders.
How many times have you had a large water bottle, or a large top heavy coffee or pop, spill out of the OEM cupholders on the Airstream?
Many have tried to add a spacer holding a sheet of plexi above the surface to stabalize the cup.
I added a scrap piece of plexi to the surface but it did not do the job. If the hole is cut to hold the big cups, the small base on the others will still allow it to tip over if you hit that big dip on the corner at the bottom of the hill.
Simple solution:
Take a cap off a spray paint can and cut the solid top off it with the grinder. You now have a bushing that fits tightly into the cupholder, and secures the smaller base cups.
If not needed, it can be pulled out, and because it is light and flexible, it can be stored anywhere nearby.
No more spilt milk!
Dave
Name:	deer and motorhome july 2011 042.jpg
ID:	134857   Click image for larger version
Name:	deer and motorhome july 2011 040.jpg
Name:	deer and motorhome july 2011 043.jpg
ID:	134859   Click image for larger version
Name:	deer and motorhome july 2011 044.jpg
Old 07-15-2011, 03:19 PM   #2
masseyfarm's Avatar
Images: 58
Timeless
I came across this Yacht Clock and couldn't resist.
Installed it above the media desk on the bottom of upper cabinet.
Out of the way, but visible from most sitting areas in the Clipper.
The tick-tok is relaxing at the end of a long driving day.
Dave
Name:	deer and motorhome july 2011 036.jpg
ID:	134861   Click image for larger version
Name:	deer and motorhome july 2011 037.jpg
Name:	deer and motorhome july 2011 035.jpg
ID:	134863   Click image for larger version
Name:	deer and motorhome july 2011 033.jpg
Old 07-15-2011, 05:27 PM   #3
masseyfarm's Avatar
Images: 58
Passenger Side Screen, Fresnel Lense
Needed a screen on the navigator side to avoid loss of important papers while travelling the continent.
Used a spring wire from an old lamp shade, and cut up some 1/4" plastic hose. Slit the hose lengthwise to slip over the spring wire and hold the screen tight.
You can now mould the wire to the shape of the window with the joint at the front, below the window handle. Join the wire here with a solid piece of the hose.
Now you can pull the screen tight from all angles and snap the cut pieces of hose over the screen to keep it in place.
I managed to make mine a little shorter than I wanted, but it works great and I can make another when I have more time.
There are plastic type retainers on the outside and inside of the sliding glass that lift out. Reinstall them after the screen is imbedded in the channel.
Another aid in manouvering in town traffic, is the addition of a Fresnel Lens for the passenger side window.
I have since moved it forward about 6" to the window handle frame so that I can see it while the navigator is seated.
Inexpensive safety update.
Dave
ID:	134888   Click image for larger version
Old 07-16-2011, 05:00 AM   #4
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Dave, love your easy fixes & updates. We took a different approach to the wooden cup holder in our LY....When we recarpeted, we did not have it reinstalled. We never found it to be very user friendly. It allowed drinks to tip over & if any thing was in or on it, the doors to the media cabinet were blocked. Now that it's gone, we have room for a little table between the chairs (used when we're parked) and I can easily get to the atlas while we're moving.
Schools Out is offline   Reply With Quote
Old 07-16-2011, 02:17 PM   #5
masseyfarm's Avatar
Images: 58
If your holder was the same as this, -- What about relocating the oak cup holder to the floor beside the driver seat. I have a holder there to store my extra bottle of water and a round hand-wipe container that I access while driving after eating popcorn. You can purchase various sizes to fit the existing hole or modify the oak holder? Could also hold other items as needed? It should be low enough for the seat to still rotate. Or cut it in two and install half beside each seat butted to the sidewall?
I hate to see a good piece of oak go to waste.
Dave
Old 07-16-2011, 03:18 PM   #6
Rockford , Michigan
Images: 12
Yup, that's what it looks like. Now imagine a tall water bottle or coffee cup in that shallow (1 inch deep) cup holder...then try to open the media cabinet (black) door with cups in place. The door catches are some kind of spring that sends the door flying open knocking the said beverage containers over....oh, the cell phones are in the square opening between the 2 holders. I'm grabbing the cups hoping to spare the cell phones from a watery death which causes John to get distracted & he's riding the rumble strips (again)...OK, I'm being a little bit dramatic. Really, we enjoy our coffee, water, etc while moving down the road & found some hanging cup holders that hold whatever size cup/bottle we put in them. Last trip I added a small basket for the cell phones, coins, etc. Worked great.
We won't "waste" that piece of oak...if we can't repurpose it, it will be tucked away for the next owner.
Keep those ideas coming...
Old 07-17-2011, 10:49 AM   #7
masseyfarm's Avatar
Images: 58
Clipper
I don't wear glasses anymore, but need reading glasses when the light is limited.
Seems every TV/DVD remote is different so I need glasses to see the little buttons on the controllers while winding down in the BR.
Installed a holder and leave glasses in it all the time. Now I always have glasses within reach.
This is our internet HUB mounted in the upper pass. side w/s window pillar. Out of line of sight and up above other signal blockers in the Clipper.
Powered from the house batteries (#2 battery bank), from the plug/power bar in the upper cabinet. (now that I have replaced the front 400W invertor #3 battery bank, with a 1000W I may switch the hub to this circuit?)
The holder is made from a scrap piece of plexi. heated and folded. Behind the hub, in the corner of the w/s, is the Bluetooth GPS. For charging the BTGPS I just plug it into the hub.
Note:
The XANTREX invertor has an option which allows operation without the charger while not on shore power, or aux. power. If you find your invertor hard on batteries, check to see if the charger is running at all times. (the invertor will use more power than it will produce) On the Clipper, the control panel over the microwave must be removed and the dip switches on the rear of the invertor control changed. This is also where you set the charger for acid bath or glass mat batteries.
We generally leave the XANTREX invertor on at all times, as we have enough solar to keep everything going.
Dave
ID:	135076   Click image for larger version
Old 07-19-2011, 04:47 AM   #8
Rockford , Michigan
Images: 12
More neat ideas. Thanks for posting.
Old 10-28-2011, 02:59 PM   #9
masseyfarm's Avatar
Images: 58
Washroom Carpet Option
There is nothing worse that carpet in the toilet area that can not be washed.
With grandchildren and other traffic using the area, it was always a concern.
On the OEM Clipper, and I am sure many others models, the utility corridor on the drivers side was boxed with plywood with carpet glued and stapled to it.
In 2008, I tore this box out and replaced it with ABS, which was easy to clean, and I had no worries about the hygiene of that area.
To give a finished look to the ABS pipe, I trimmed it with gold stair nosing, that blends in with the other bath fixtures and trim.
Dave
Name:	Airstream Rain 015.jpg
Old 12-12-2011, 09:08 PM   #10
1998 30' Cutter Bus (Chevy)
Sarasota , Florida
Great ideas guys. Jim
jcessna is offline   Reply With Quote
Old 12-21-2011, 10:56 AM   #11
Yes, Great ideas!
Old 02-10-2012, 09:18 PM   #12
masseyfarm's Avatar
Images: 58
Battery Disconnect Switch
After numerous incidents of accidentally shutting off the house battery disconnect switch, located at the entrance with the other switches, I have installed the simplest solution that should work.
I cut a small piece of plexi glass to fit over the switch to hold it in the "on position". The plexi pivots so that the switch can be shut off if wanted.
As you can see I used a small second piece to act as a spacer.
I was already to install a recessed switch, but this looked to easy.
Dave
Old 02-20-2012, 12:41 PM   #13
masseyfarm's Avatar
Images: 58
Applies specifically to the Clipper, but a similar modification may help other overhead video cabinet requirements.
The overhead center mounted cabinet, required for the original large TV that was OEM installed, projected out enough to become a real head banger if one had a short memory like myself. (Its amazing how many times you can hit your head on the same item before you are motivated to make an alteration.)
As the physical size of TV's shrank, there was no longer a need for the box to be that large so in 2008 when we installed the LG HDTV I trimmed the box back to line up with the side cabinets.
Careful trimming allowed the angle and depth to be altered without having to change the vinyl, and resulted in approx. a 4" gain at the critical bottom corner of the cabinet.
You can see I also added additional map lights that actually shine on the drivers location, so that a map can be placed over the steering wheel and have good light directed on it.
Dave
ID:	151581   Click image for larger version
Old 02-28-2012, 02:14 PM   #14
masseyfarm's Avatar
Images: 58
Applies to Clipper, but the basic idea should work on most RV's.
In most RV's the floor space is valuable real estate. To help with this, in 2008, I made up and installed a couple oak colored ,wood magazine style, stands in the bedroom to hold SOME of my spouses shoes. (No, she is not Imelda Marcos, former first lady of the Philippines who was infamous for owning thousands of shoes.)
The shoe holders keep the shoes off the floor, are out of the way and do not use up any space that was otherwise usable. They are mounted off the floor so that your foot still has the original toe space while standing or walking by and the vacuum will move below them.
For my Clipper pusher, the mounting had to leave enough room to be able to stand the mattress against the wall if upper engine access was required. The unit installed at the lower drawer did not take a drawer space, as that is the air intake for the Cummins CT300 behind that blank. This one has a bottom in the holder to allow it to hold a magazine if wanted for bedtime reading. The other, on the BR front wall, has an open bottom that the shoe slides down into. This will hold 4 pair of sandals with ease. It was also mounted to allow and protect the fire extinguisher in the corner that is also mounted above the floor, to allow the vacuum to move under it.
I should point out that the Clipper originally had a pocket door at the entrance to the bedroom that we have removed which allows space for the front holder. We found that this door was not necessary, as there is also a pocket door at the kitchen entrance. This also allows a coat hanger assembly to be mounted on the upper part of this wall. No picture at this time.
Dave
ID:	152194   Click image for larger version
Clipper, GPS, Laptop Stand, Land Yacht masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 24 07-11-2015 02:16 PM
Clipper, Land Yacht, Headlights Flashing masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 02-25-2015 09:37 AM
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Cameron Lake, Alberni, The Hump, Clipper masseyfarm On The Road... 3 05-07-2011 08:57 PM
