Old 04-07-2011, 06:30 PM   #1
TorpedoFamily
Torpedo Family's Avatar
2005 30' Classic
2014 30' Classic
Ozark , Alabama
Class A double pane windows
I am having ALL my windows re-worked because of clouding. Suncoast Designers in Hudson, FL is doing to work. Looks like good work, poor orginization of workers for timely completion of each job. They said all windows manufactured after 2004 will fail. All Mexican manufactured.
Torpedo Family is offline   Reply With Quote
Old 05-03-2011, 02:31 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Sealed Window, Thermopane
Any more news on the re-work? Any problems?
Dave
Old 05-03-2011, 04:03 PM   #3
1985 31' Excella
Fresno , Texas
I don't think Mexico is the cause of failures in insulated glass. I once owned a Four Seasons Solarium Franchise. The sealers are much better today than the were in the 80's. When repairing the failed panels we would find dried out and cracked sealing compounds. This is not a workmanship problem it was a product choice problem. There is another problem with insulated panels in a RV and that is altitude. If you are at sea level and go to the mountain and over a few passes you have that pressure at sea level trapped inside the panel flexing the glass outward.
Panels that had to cross mountain ranges had a small lead vent tube in them to relieve pressure. When we unpacked the glass we would crimp the vent tube closed.
Insulated glass panels are made with glass coming out of glass washing machines, the spacer with desiccant is installed on the glass then the second glass is put in place and a gun forces the sealant under pressure into the edge area of the panel.
If a panel is poorly manufactured or has a improper seal then the glass panel will usually fail within a few months. When it takes years then it can be seal material failure or even a poor design of how the frame compresses the glass unit or as mentioned earlier changes in altitude physically tearing the seal apart.
R-20 glass panel.
Tri-Film/Quad-Cavity Heat Mirror Insulating Glass using three Heat Mirror films suspended inside of an insulating glass unit, creating four air spaces, is the most energy-efficient glazing product in the world. With an optional Xenon gass filling, tri-film/quad-cavity Heat Mirror Insulating Glass can achieve an industry-leading U-value of 0.05 (R-value of 20). For home owners with demanding applications, or for those who want the best, Heat Mirror is the clear choice.
Wsmith is offline   Reply With Quote
motorhome
Interesting Craigslist finds GreatPumpkin Our Community 2095 07-11-2017 08:13 PM
Vista View Windows.. this can't be right DanielB Windows & Screens 10 03-01-2011 09:22 PM
Is there a basic maintenance/upkeep class? dgray General Repair Forum 5 02-22-2011 03:36 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
