Old 02-04-2012, 06:00 PM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Check engine
i stop my engine and when i try to restart it was very difficult,and when it start i have a check engine and i can,t go just 30 mph
I am stock
landmarc is offline   Reply With Quote
Old 02-04-2012, 06:22 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
On the Cummins they had a replacement program on the shut down solenoid.
I believe yours is a Cat so you will have to check.
Dave
I am stock
Old 02-04-2012, 08:44 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Called get home mode, engine is trying to protect its self, if you are close to home or a dealer to get help.
Old 02-06-2012, 05:25 PM   #4
2005 28' Safari
Mono City , California
Landmarc,
If you are still having the problem, I maybe able to help.
Dave in post #2 stated that yours should be powered by a Cat engine. If it is a Cat, if you can get the engine serial number from the valve cover engine data tag. The serial number will start with a prefix with 3 letters and or a combination of two letters and a number, example 1AJ or 5GL or CKM. If you can get the serial number prefix, I can get you some info regarding your problem. I have access to the Caterpillar Service Information System.
Do you know if there is a diagnostic switch on the dash, or maybe under the dash. Most truck manufactures have a switch installed, not sure if the chassis manufacture for the motorhome you have has one installed. If there is one, you can flash out the diagnostic code. If so give that to me and I can get you the troubleshooting info.
If the motorhome has a Cummins engine, I will need the engine serial number also. There should also be a tag on the valve cover or on the left front of the gear case cover. The serial number is all numbers 7 or 8 digits. I can get service info for Cummins engines also. If Cummins powered, there may also be switch to flash out the codes.
When I know what engine you have I can get you the info on the procedure to read the codes.
Good Luck
Tom
TBSarfari28 is offline   Reply With Quote
City/water tank check valve gunner Classic Motorhomes 5 10-03-2011 06:49 AM
Replace engine in 95 LandYacht Diesel cjshaffer2 Land Yacht/Legacy Motorhomes 4 09-25-2011 07:40 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
MH check up. To-do-list Octane General Motorhome Topics 9 04-14-2011 02:36 AM
I just sent my check for a 68 International La.2Ak. Member Introductions 5 03-24-2011 10:09 PM
