Old 09-17-2015, 05:19 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Broken Window?!
So on the escape window in the bedroom, the glass is broke on the non sliding section. Looks like someone shot it with a gun! (might return the favor if I catch the son of a gun)
So, where can I get a replacement and has anyone ever replaced one of these themselves and can give advice?
JourneytoRet is offline   Reply With Quote
Old 09-17-2015, 05:35 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
On the fiberglass motor homes, window replacement is easy, though not cheap.
Remove the curtains/blinds from inside, and remove all the phillips screws from the inner frame. The window assembly should then fall out. It may need to be gently persuaded with a putty knife between the frame the the outer wall.
Old 09-21-2015, 06:24 PM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
The emergency window is hinged on the top.
You can pull the lever on the right and push the fear out.
There are couple companies the can make it our Airstream maybe has it.
Peter
PSchw is offline   Reply With Quote
Old 02-13-2016, 04:43 PM   #4
israndy's Avatar
2005 39' Skydeck
Alameda , California
Say JourneytoRet, I am curious about your window. Did you ever get it fixed?
Oh, Curious about your step light. Did you ever figure that out?
Oh, and your blackout shade?
The backup camera? Is that working now?
Do all 4 speeds work on your dash AC now?
Not picking on you, more one stop shopping. Hope you have a fix for some of these and if you do I am sure others will benefit from your experience. I have learned a LOT from this site.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
The Window Curse is Broken!! pinkflamingoes Windows & Screens 32 06-01-2006 11:18 PM
broken window,'82 Excela MH dorothywhitt Airstream Motorhome Forums 1 08-16-2005 04:41 PM
Broken window cjholloway Windows & Screens 4 03-31-2004 06:26 AM
Broken front right curved window RREGESTER Windows & Screens 1 02-09-2003 09:05 PM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 04:22 PM
