Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 06-02-2011, 06:57 PM   #1
1997 32' Cutter Bus Diesel Pusher
rincon , Georgia
Brakelights not working...
1997 cutter pusher
all lights work except brakelights?
have 12v at brake switch,fuse and relay
the strip brakelight airstream installed workes.
freightliner chassis sent wiring diagram looks like brakelights use the same
wires as the turn signals and flashers
if anyone knows where the wires common connection is located. has to be in a switch somewhere
teesitup is offline   Reply With Quote
Old 06-02-2011, 07:33 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Welcome to the forums.
You say you have power at the air activated brake switch under the floor of the driver position? When air applied you have power coming out of that switch? I had that wire break at the switch. You say you have power at the small brake light. Sooo-
Have you tested with a digital meter the brake lights when brakes applied?
Have you got brake lights at the towing plug?
I would say this connection, between the tail/brake and the plug circuit, may be faulty, as it is the most likely to have been disturbed by untrained "techs"
Dave
Originally Posted by teesitup View Post
1997 cutter pusher
Old 06-02-2011, 08:18 PM   #3
rincon , Georgia
i have 2 switches power on both when brakes applied
traced wiring to fuse 15 amp stop and hazard
traced wiring to brake relay switch relay working power in power out
no voltage at towing plug for brakelights
towing plug turn signal and running lights work
plug from chassis to back of unit running lights turnsignals flashers all have power
the stripbrake light airstream installed has seperate wiring option brake light listed on freightliner wiring diagram
need to talk to freightliner tech
Old 06-02-2011, 09:54 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Check your turn signal switch at the steering column. If your brake and turn signal lights are the same light than the brake circuit goes through the column switch. The center brake light is a separate switch as it does not flash.
Cheers, Dan
Old 06-03-2011, 09:12 PM   #5
rincon , Georgia
Brake lights
97 cutter pusher brakelights not working
turn signal flashers and taillights work
the strip brakelight works
have power at brake switches
power in and out stop and flashers fuse 15a
power in and out at brake relay
anyone know where a fuse or switch could be located that iam missing
Old 06-03-2011, 10:07 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
You wrote: "have power at brake switches"
Which switches? Where are they? More than one?
Old 06-03-2011, 10:50 PM   #7
Bad Monkey's Avatar
1972 25' Tradewind
Leslie , Michigan
If both rear brake lights are out, but center brake light is working along with turn signals. Would make me think you have an electrical short. I would get a power probe to and start checking wireing.
Bad Monkey is offline   Reply With Quote
Old 06-04-2011, 06:20 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are your turn signals separate from your brake lights?
Do you have a brake controller installed for towing a trailer?
Can you post a pic of the back of your bus.
Old 06-04-2011, 08:02 AM   #9
rincon , Georgia
brake lights
2 switches located under drivers compartment 12v out on both
thanks for the tips will be checking wiring today
freightliner e-mailed wiring diagram of the chassis looks line the brakes and turn signals operate togeather will be checking that unit today
no pic at this time maybe later
Old 06-04-2011, 11:16 AM   #10
Splitrock's Avatar
This is probably off topic and off the wall, but my Chevy pickup operates the brake lights off one switch located above the brake pedal. The switch is an "always on" switch. The pedal's job is to turn the switch off. Those switches fail. I've replaced mine twice since I bought the truck new in 1987. Just a FYI.
Old 06-04-2011, 12:40 PM   #11
Splitrock's Avatar
Okay, I understand now. You have located two brake switches at the driver's location that both indicate they have power when the brake is applied. That's a good sign. Now it's just tracing the wire(s) to the rear and checking grounds at fixtures. I'd think if the brake lights use the same bulb as the flashers and the flashers work okay, then the grounds are fine.
If it's a wire issue, it may be easier to just install a new wire than find the original wire and then find the exact problem point in the original wire. Whenever I run a new wire, I add an accessible fuse to the new line. I've never been sorry I've been too careful.
Gary
Old 06-06-2011, 07:21 PM   #12
rincon , Georgia
brakelights update
the main brakelights run through the flasher switch
jumped the wire and presto brakelights
need to trace the wire back to a brake lamp switch and then to the battery junction? the hot wire has a 20 amp inline fuse sure the fuse is blown location is a mystery? power is supplied through the brake lamp switch to the flasher switch
center brake light or strip light runs through 15amp fuse to brakelight relay
anyone know where the battery junction is located on an airstream bus deisel pusher chassis freightliner
Old 06-07-2011, 06:50 AM   #13
masseyfarm's Avatar
Images: 61
The battery hot/distribution on the front of the Clipper is on the front bulkhead, forward of the driver position, access from the outside panel. All power at the front of the unit feeds off this point. Because it is somewhat exposed to the elements, a poor contact to hot is possible.
Dave
Old 06-09-2011, 08:07 PM   #14
rincon , Georgia
brakelights
thanks everyone for the info
freightliner xc and vc models built before 4-28-98 has a single diode installed in the brakelight circuit. which will blow if to much current .
freightliner custom chassis issued a sb 54.3 retofit, new brakelight diode harness with two diodes pn 06-28598-00
i have a blown diode will jump lights from switch cut out diode install 20amp fuse will not be able to use flasher and brake at the same time
hope i can fine the retofit harness
thanks everyone
info: freightliner custom chassis service center in south carolina very helpful e-mail wiring and sb 54-3
Old 06-11-2011, 09:01 PM   #15
rincon , Georgia
brakelights fixed
today had time to work on the cutter. son pulled out last night going to kansas city. spent time helping him get his 1946 spartan manor tin can travel trailor ready fist tow after rebuild. tonight in joelton tn off I-24
if you see a u-haul with alum tin can thats him
back to the cutter found a fix for the brakes lights third page of sb 54-3
instead of new wiring harness down to radio shack picked up diodes installed today cost $3.62
Old 06-12-2011, 06:35 AM   #16
masseyfarm's Avatar
Images: 61
Pictures would be great.
Where is the location of the original harness diodes? and where are you installing new?
Dave
  • Service Bulletin - SB 54 - 3
Brake Lights quit working on coach
If your '98 or '99 coach has it's brake lights go out, here is info on the two diode wiring harness (replacement for the single version).
Freightliner Service Bulletin 54-3
Part Number 06-28598-000
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Docking Lights not working 396 XL Torpedo Family Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 13 02-04-2011 02:10 AM
