Old 05-24-2013, 07:49 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
brake controller, a little help please
I want to add a brake controller to the MH. I have had good luck with a Tekonsha controller in the past.
Has anyone added a brake controller to their MH? Can you give me your setup?
Also, I saw a MH towing a car on the highway and they had lights stuck on the car for signaling. Any recommendations there? I am towing a vintage prelude.
JourneytoRet is offline   Reply With Quote
Old 05-24-2013, 08:53 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
I have some information on my Clipper setup here.
http://www.airforums.com/forums/f463...ml#post1026482
Depending on your location, you might be required by law to have a breakaway brake system installed on your toad.
I see you are in NY and that state weight limit for brakes is 1000lbs. So you will have to have an emergency breakaway system installed if I am reading it right.
http://www.roadmasterinc.com/products/braking/map.html
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 05-24-2013, 09:32 AM   #3
ah, need to update my location!
anyway, I'm actually going to tow the prelude via a towmaster dolly w/electric brakes, which should change the suggestions/recommendations (sorry about that!)
Old 05-24-2013, 09:51 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I've got a 2012 Interstate, flat-towing a 2013 Honda Fit (see picture), so it's probably not directly comparable to your setup.
If you're using a dolly, then supplemental magnetic-base lights would be the way to go. Roadmaster makes a pretty good set. On edit— The dolly may already have brake lights/turn signals on the fenders, so you might not need supplemental brake lights on the car in order to be legal.
Dolly should already have a breakaway system for the brakes, so no worries there.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
