Old 01-20-2005, 06:51 PM   #1
block heater
I'm sure I missed it in the manual, but do you have to do anything other than plugging in the cord hanging behind the radiator to get it to work?
anthony
apetit is offline   Reply With Quote
Old 01-20-2005, 06:55 PM   #2
RichardT's Avatar
anthony
It is No more than a heater and plugging it in is all that is required.
You should be able to feel warmth if you wer to put your hand near it while it is plugged in.
RichardT is offline   Reply With Quote
Old 01-20-2005, 07:01 PM   #3
WayWard Wind's Avatar
2004 25' Safari
What to do? What to do?
Well for starters you should make sure there's power to where you plug the cord into. I'm not sure in what you're block plug is installed in, but up here we have them in most all vehicles & use them just to make sure the vehicle will start if it gets cold . Sometimes, well most of the time if it's cold & we plug them in you can hear the heaters start to warm up.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
'78 Argosy central heater motor home edmatlock Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-22-2002 10:57 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
