On my XC the disconnect is a solenoid located in the engine well, there are 2 or3 next to each other, my disconnect is the one on the roadside of the well I believe, to late at night for me to go lift the bed and check, this is from my memory which can be pretty sketchy even early in the day good luck. Ron
Thanks for the response. I will look at that tomorrow. My coach has been in the upholstery shop getting new carpet and upholstery.
New question :
Have you adjusted the slide on your coach? Mine on the top left side doesn't close all the way. About 2" more is needed.
Just wondering.
Have a great day.
No I haven't had that pleasure (slide adjustment) I have look mine over and there doesn't appear to have a lot of adjustments, two way ram and rails all under the slide I will look at it again and see if I notice anything of note. Ron
