Old 07-17-2015, 08:07 AM   #1
SteveH's Avatar
Common Sense , Texas
Batteries?
Searched for this information, but couldn't find it, only the typical "discussions" about what type is best.
What batteries are in a Diesel pusher XL, both house and engine, where do you buy them, and what do they typically cost? Mostly interested in engine batteries, as I think I can figure out the house battery thing.
Regards,
Steve
Old 07-17-2015, 08:46 AM   #2
israndy's Avatar
2005 39' Skydeck
Alameda , California
I cannot help with direct info, I just had new batteries put in my new to me 390. I am having work done before I pick it up and batteries is one of the items needed. The dealer went to Sam's club and got 2 Group 8D cells, they are just under $200 each. I was concerned as the original space was for Group 4D, which has lots less capacity, but he says the 8D fit with just a smidgen of space extra. I haven't seen it, but I am happy I got the biggest to fit. The engine batteries appear to be a bunch smaller but I don't have the unit or the manual yet.
Photos from the internet:
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 07-17-2015, 08:51 AM   #3
SteveH's Avatar
Randy, are those two 8D batteries the engine batteries, or the house batteries?
Regards,
Steve
Old 07-17-2015, 01:55 PM   #4
israndy's Avatar
2005 39' Skydeck
Sorry, yeah, you do NOT need the capacity of an 8D to start the engine, even in deepest winter. No the little ones on the right are the start batts, but I don't have one in front of me and the pic is too low rez to see what they are. The Freightliner manual will say what goes there, but it looks like I pretty broad mount, you may be able to put any two batteries you can get on sale in there. Typically 12 volt batteries wired in parallel like you see there. You can also do two 6 volts in series, but not so common in starter batteries.
I am happy with how easy the batteries appear to be to do maintenance on, lots of space for watering. On the smaller RVs often times they will ONLY allow you to put AGMs in, as there is no under body storage for batteries. AGMs can be expensive.
-Randy
Old 07-17-2015, 02:29 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Unless you drive a Prevost or Newell. Both of those coaches use a pair of Lifeline 8-D's for starting.
Then again.......... They run at 24 VDC
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-31-2015, 06:39 AM   #6
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
For me, great timing for this question. I need to get engine and coach batteries as well so I hope someone will post with some recent info on sources, types, cost, and review of their purchase with respect to a 2000 Land Yacht.
JourneytoRet is offline   Reply With Quote
Old 07-31-2015, 11:28 AM   #7
israndy's Avatar
2005 39' Skydeck
I got the Sams Club 8D Batteries: Energizer 12 Volt Commercial Battery - Group Size 8D - Sam's Club
Not sure what the engine batteries are as I have not taken delivery of the RV yet, nor have I seen how the 8Ds fit. The coach originally came with 4Ds, but they are on a big tray, so I can see there is very likely LOTS of space to put 8Ds and they have the most capacity of a single battery.
-Randy
Old 07-31-2015, 11:49 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If you need 8d or 4d you might consider a cat dealer, they are a very good battery. I have not seen a 24 volt starting system in years, most big trucks have 3 group 31 batteries and they start very well in very cold temperatures.
Old 07-31-2015, 02:58 PM   #9
lewster's Avatar
Rather than dealing with a 165 lb. behemoth of an 8D battery, which has a 255 amp/hour capacity, you would be way ahead of the game using a pair of Lifeline GPL-6CT golf cart batteries.
They take up a smaller footprint and give you a 300 amp/ hour capacity. And at 86 lbs. each, you can actually handle them yourself.
Lew Farber
541-490-6357
Old 08-03-2015, 07:37 AM   #10
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Lewster great idea I need to change soon my 2 8D house batteries on my Skydeck too. I also want to upgrade on inverter/charger to Magnum you have any suggestions ?
Now I got a 2000w centrex which is 10 years old and still works. I like to add an auto start for the generator.
As I am not in a hurry I may have do it somehow sometime in the next year or so. Let me know.
Peter
PSchw is offline   Reply With Quote
Old 08-03-2015, 08:06 AM   #11
lewster's Avatar
Peter
Peter,
In the space of 2 8-D batteries, you can place 6 Lifeline GPL-6CT 6VDC golf cart batteries with a combined total of 900 amp/hours. I've done this several times on pushers.
You can also do a fairly straight-across upgrade to your Xantrex inverter with a Magnum MS-2812 (2800 watt pure sine wave) and the ME-RC remote. It uses the same communication cable and will more than likely fit right into the same space that the Xantrex monitor does now.
Only thing you have to change is the battery temperature sensor.
Let me know if you have any other questions.
Old 08-03-2015, 07:40 PM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I checked cat batt. 1500 CCA with 465 reserve capacity minutes weighing 132 lbs....
Old 08-03-2015, 09:17 PM   #13
PSchw's Avatar
Livingston , Texas
Lewster could I run a residential fridge on this or should it be a bigger inverter and more batterie capacity? How about the generator auto start Magnum offers?
I need to keep my beer cold and the Dometic does do a good job it is either too cold or to warm.
Peter
Old 08-04-2015, 12:19 AM   #14
lewster's Avatar
Peter
If you are looking to replace our fridge, I would stay away from residential units and investigate the marine market offerings.
I have replaced many over the last couple of years. A couple of well known manufacturers are Isotherm (Indel Webasto Marine) and Vitrifrigo. Both are made in Italy and offer Danfoss compressors that operate on straight DC, so no inverter is necessary.
They can easily operate on a quality solar charging system (300-400 watts) coupled with a 300 amp/hour AGM battery bank. Or if you really want to go high tech, a much lighter 300 A/H lithium battery pack will offer you 240 usable amp/hours over the AGM's 150 for the same gross amp/hour rating.
Other benefits of marine refrigeration are operation up to 30 off level and the ability to take a pounding! Residentials are made for a house, and the last time I checked, they don't tilt or get banged around like a boat (or RV) does.
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 08:26 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
