Old 01-21-2014, 11:27 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Ants
What tried and true (successful) methods have you used to help keep ants out of a RV? We've spread antkiller around the tires, jacks, anything that touches between the ground and RV.
JourneytoRet is offline   Reply With Quote
Old 01-21-2014, 12:02 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ant traps inside and dryer sheets.
MICHAEL
Old 01-21-2014, 12:07 PM   #3
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Perserverance-
You'll get 'em.
Powder, baits, spray- they'll eventually get up outta there-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 01-21-2014, 12:09 PM   #4
Pet Sitter Extraordinaire
kposey's Avatar
1975 27' Overlander
Chattanooga , Tennessee
Images: 56
Terra Traps. You can get them at Home Depot or Lowes. They take it back to the nest and share. Takes about 1-2 weeks, but it does get rid of them.
Kathy, Tommy, & Crew, Chattanooga, TN
Air #2757
1989 SquareStream (Annie #8)
kposey is offline   Reply With Quote
Old 01-21-2014, 12:18 PM   #5
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Follow them to their point of entry and seal it. If they are Carpenter ants you might have have to track down the queen. I'm my case it was removing the foam insulation. Or you can get a ant eater? Lol
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 01-21-2014, 02:24 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Throw a sacrificial Oreo UNDER the camper.
Good bet - ants are caravanning up your power cord or your tires. Treat topically.
Paula
Old 01-21-2014, 02:25 PM   #7
dznf0g's Avatar
Oswego , Illinois
X2...I use them in the house too.
-Rich-
Old 01-21-2014, 03:32 PM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If you're looking to prevent them entering, you could try using DE (diamataceous earth, might have the spelling wrong) around the outside of the trailer. It is a naturally occurring white powder that works by dehydrating insects that get any of it on them. You will have to replenish it after a rain or every few weeks.
I vote for Terro too, it kills the whole nest, but you will initially get a LOT more ants into the trailer for a few hours before they suddenly all disappear.
Good luck!
Kay
Old 01-21-2014, 03:35 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Make sure no tree limbs are touching the top of your trailer. That happened to me a few years ago when I arrived at my site after dark and did not notice the limb touching. That was the worst ant infestation I have ever heard of. DW woke during the night with ants crawling on her. Next morning we discovered the ants got into the cupboards and we had to throw out a lot of food that got contaminated by thousands of ants.
I'm fighting an infestation right now, no ants on the ground that I can see, but they're all over the top of the trailer. There are very few inside. I'm using traps and spray inside, and using dust and liquid outside.
Alan
Old 01-21-2014, 03:48 PM   #10
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
As kposey mentioned, the Terra products work well. I have had positive results every time. A few drops on the ground near each contact point ( tongue jack, stabilizers, tires, etc. ) and if the weather is dry, it usually takes care of the problem in a few days.
Ant Problem? Terro = Ant Control Solutions
Otherwise, try to keep sweet or fatty foodstuffs well sealed and clean the stove ( including under the burners ) well to reduce the attraction.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
