Old 01-22-2014, 09:58 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Air Compressor & Tire Gauge
Hey folks. Somewhere, maybe in the manual, I thought there was access to the MH air compressor that would allow me to among other things, put pressure into the tires. Is my memory failing me?
Also, I suspect I'd want a good quality tire gauge for these mammoth tires, any recommendations?
Finally, I think in another thread, I read that the tires need to be replaced every 5 years. These Mich look new but is there a way to tell when they were made (not installed, obviously). What's the general feeling on this please?
JourneytoRet is offline   Reply With Quote
Old 01-22-2014, 11:23 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I can't answer about the air compressor, as I have a trailer, but-
A DOT man recommended to me the little digital tire gauge form Walmart. He said that's what was recommended to him by the DOT officers that trained him.
It is a Slime model #20017- $9 on Amazon- don't remember how much I paid at Walmart, and their website will tell you everything about it but the price-
They use them to check the pressure in 18 wheeler tires.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-22-2014, 11:45 AM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
All the tire age info you need can be found here:
http://www.tirerack.com/tires/tirete....jsp?techid=11
SeeMore is offline   Reply With Quote
Old 01-22-2014, 01:24 PM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
Air nipple should be located on the front bulkhead where there is a manifold for air lines. This is the only approved location to tap into the air system. Yours may be in the front compartment located below the driver, forward of the wheelwell.
On the CLIPPERS, it is located on the drivers side front bulkhead accessed via the front hood/door. Upper drivers side on this unit behind the front access door.
If you also have a front access door and not a genset up front, yours should be in the front also.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
