Old 04-15-2012, 08:41 AM   #1
1998 35' Cutter Diesel Bus w/slide
Laud by the sea , Florida
Acme A/C Parts
This is a link to virtually all of their products;
http://acmeairparts.com/images/acme_parts.pdf
mfancher is offline   Reply With Quote
Old 04-15-2012, 09:59 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Clipper, Acme, Land Yacht, Cutter
Thanks for posting that ACME find. Now if you can just find a supplier for all these parts. Some, I am sure, can be supplied by other OEM.s and modified to fit.
Dave
Old 04-16-2012, 08:20 AM   #3
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
I had the heater core replaced by a Ford truck shop in South Carolina, USA about two years ago, so maybe a repair shop could get the parts you need.
BarnacleBill is offline   Reply With Quote
Old 04-16-2012, 10:08 AM   #4
Here is another resource for A/C parts;
http://www.soldbyrichard.com/images/acme_parts.pdf
Old 04-16-2012, 10:09 AM   #5
Thanks, Im sharing what I have found. Virtually every a/c part is available...
Old 04-16-2012, 10:56 AM   #6
masseyfarm's Avatar
Images: 56
This just gives the same part details. Did you find a source for this ACME struff????
Dave
Old 04-16-2012, 06:51 PM   #7
98 cutter a/c main components
since im diagnosing why my compressor is not engaging, Im sharing photos of the major components;
Evaporator in the dash
Compressor on the motor
Condenser on the chassis
Trinary switch, thermostat and main power feeds are all up front above the generator...
ID:	155981   Click image for larger version
ID:	155983   Click image for larger version
Old 04-16-2012, 10:18 PM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Acme is a very old established company.
They got their start years ago selling road runner traps to coyotes.
Ken
Old 04-17-2012, 06:57 AM   #9
Streamin'
Dave
Try this link Dave A/C Parts Automotive and Motorhome
Old 04-17-2012, 07:15 AM   #10
Streamin'
Read the manual...
Old 04-17-2012, 09:29 AM   #11
masseyfarm's Avatar
Images: 56
Thanks again for the leads. I have had no problems with mine to this point, other than the push button dash control.
If we post availability of parts as we find them, it will make it a lot easier for those who are sure to follow.
Dave
Originally Posted by BarnacleBill View Post
Read the manual...
