Old 05-18-2014, 12:18 AM   #1
Lucas S
2000 36' Land Yacht XC Diesel
Fresno , California
AC Issues
First off, I have a 2000 Land Yacht XC. So I finally figured out how to go between zone 1 and zone 2...I installed solar panels, but I know the AC only runs when the generator's on. I had the generator on and Zone 1 was working, then I turned it off so I could run Zone 2. Zone 2 will turn back on and off, but Zone 1 will not now. I was hoping I could flip a breaker switch like I did in my previous motorhome. I found some breakers under the front of the bed, but they didn't seem to do anything. I found the fuses directly next to those and they're listed, but those are just fuses. So, any help would be great!
-Lucas S
2000 Land Yacht XC35 Diesel
2007 Hummer H2 Tow Car
1999 Fleetwood Bounder
2004 Saturn Vue Tow Car
1998 Fleetwood Avion 38F
Lucas S is offline   Reply With Quote
Old 05-20-2014, 04:11 PM   #2
Caldwell , Idaho
Do you have the same problem on shore power or only genset?
Ron_Kat is offline   Reply With Quote
Old 05-20-2014, 10:07 PM   #3
Lucas S
Fresno , California
Only on genset
Old 05-22-2014, 08:25 AM   #4
2006 39' Land Yacht 396 XL
Casselberry , Florida
AC power
I did not have power on some plugs and 1 AC. Found a bad relay in the transfer switch not supplying power to 1 leg. You might check that you have power in both legs whith the generator on.
Toftime is offline   Reply With Quote
Safari 25' ss & CCD 25' - odor issues? darkStar Waste Systems, Tanks & Totes 15 09-29-2003 01:28 PM
Trip report (fuel filter issues) PeterH-Airstreamer Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Water heater pilot issues? Marko69AS Water Heaters, Filters & Pumps 8 07-14-2003 09:46 AM
Safari 25' Model A towing issues rtierney 2003 Safari 11 07-02-2003 10:15 AM
Alarms, remotes, and other security issues. Griffin Airstream Motorhome Forums 19 02-12-2003 11:57 PM
