Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 05-06-2008, 07:11 AM   #1
Profile:  1991 29' Excella
Largo, Florida , Florida
95 36'Cutter rear bedroom liner hanging
Had a leak on rear driver's side where fiberglass roof seam meets side panel. Resealed and repaired exterior leak but interior roof liner became loose and is now hanging almost to the middle if the coach. Now no evidence of leak (dry) but it gets worse as we travel. Would like to fix and re-glue but concerned that glue will not adhere to the foam backing that has seperated from the liner. Anyone have any experience in solving like problem?
brodjeaw is offline   Reply With Quote
Old 05-06-2008, 07:20 AM   #2
Roadtoaster's Avatar
Profile:  2006 28' Classic
Byhalia , Mississippi
I saw a trailer with a similar problem that belongs to someone on the Forums, naturally I can't remember their name. Their ceiling material was re-attached with screws evenly spaced across the ceiling. Made it look like it was made that way, almost a tufted upholstery look. The screws were decorative with a white head that matched the ceiling material. I have no idea where the screws were purchased but I would think they would be fairly easy to find.
Hope this helps some.
Greg
(formerly known as ptrvr)
Roadtoaster is offline   Reply With Quote
Old 05-06-2008, 07:28 AM   #3
Thanks Greg. Not knowing thickness of insulation and supporting construction concerns me as to length of upholstery screws needed?
Old 05-06-2008, 11:10 AM   #4
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Using the search tool, look up the problem using basic key words such as "droopy ceiling." You should find several threads that discuss the problem and various solutions. We used the screws and white screw covers already mentioned here, and while not perfect, the ceiling looks acceptable now. We used 5/8's, I believe, which worked perfectly. We had to do this in both the front living area and the back bedroom. This was not our original idea, but was suggested by another forum member with the droopy liner. Read through all the threads on this that you can find so that you have a good idea of the variety of solutions that have been used. Good luck, and keep us posted on your success. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU. . .MALs no longer! What's a few miles among Airstream friends?
maxandgeorgia is offline   Reply With Quote
Pingbacks are On
Want a 28' with rear bedroom? ALANSD General Motorhome Topics 7 12-21-2005 08:28 AM
Rear bedroom swap for 25' Excella? caadoptees Parts Archive 7 08-01-2003 02:59 PM
Early rear bedroom motorhome?? Curtis-79MH Our Community 14 12-23-2002 09:01 AM
Early rear bedroom motorhome Curtis-79MH Airstream Motorhome Forums 1 12-16-2002 04:26 PM
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 09-14-2002 11:42 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
