1999 35' Cutter Diesel Bus w/slide
Amanda Park
4 pin plug at rear of Cutter
Hi everyone. We just purchased a 1999 Cutter DP that we love. I was wondering if someone could tell me what the square 4 pin connector, located at the back of the coach next to the 7 pin connector, is for. Is it just another version of a flat 4? Thanks
2000 25' Safari
Davidson County
, NC Highlands County, FL
According to the Parts Manual, there was originally only the 4 pin plug.
According to the Owners Manual, there was originally only the 4 pin plug.
It is a 4 wire round pin trailer plug, that functions like a flat 4 wire trailer plug
Going out on a limb, I'm suggesting it was a special wiring harness to provide brake and turn signals to a towed vehicle.
Perhaps power for a lube pump too?
This is 4-5 years later but I had a hard time with the turn/brake lights for the car dolly, 1997 Cutter. Did enough research to diagnose the problem and fixed the problem. Dolly lights work perfectly now. If you're interested in knowing more about the repair, contact me with a reply. I will go into more detail.
