Old 09-30-2016, 06:50 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
1st Time Climbing Hills
So since I've owned my first RV (5 years), we finally took a trip up 81 and beyond, to D.C. First thing I noticed climbing hills was that my temp gauge skyrocketed. My on-the-road solution was to force the transmission down which of course reduced my speed and engine temp. Is this "normal"? Or should I have my mechanic look at the cooling system?
300HP Cat Diesel
JourneytoRet is offline   Reply With Quote
Old 09-30-2016, 08:32 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is time to get some things checked.
If equipped would be the clutch fan to see if it is engaging. if an electric fan is the thermostat that controls it working and is the fan working.
Radiator may need cleaning, inside and outside.
The thermostat.
2004 Excursion 4x4
Old 10-03-2016, 03:52 PM   #3
SteveH's Avatar
Common Sense , Texas
I have the same problem with mine in the mountain passes, and whenever climbing long grades when the outside temperatures are high (90+), and everyone else that I have talked to has the same problem with similar rigs. I down shift to keep the engine RPM above 2000 and it seems to help a bit.
I have cleaned the outside of the radiator, and previous owner told me the cooling system had just be serviced a year ago. So, I don't know.
If you find the solution, please post back here so we will all know.
Regards,
Steve
Old 10-03-2016, 04:23 PM   #4
DFlores's Avatar
1968 22' Safari
Currently we are in New Mexico, coming from Texas. Slow climb most of the way, I had installed a new radiator and thermostat along with change trans fluid and filter. So far temp is good thru Albuquerque.
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 10-04-2016, 06:11 AM   #5
Replaced thermostats (2) last fall. I have an appt. with my mechanic and he will look it over. I'll report what he finds and if it helps the issue.
300HP Cat Diesel
Old 10-04-2016, 06:56 AM   #6
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Kota found a source of his overheating issue in his D P classic. To be built up oily gunk between elements of the radiator assembly.
Couldn't be seen till they were separated.
He shared good details in his posts in the classic Moho thread, And is very helpfull. Send him a pm
Or look thru his old posts.
Temps skyrocketing does not sound good.
Hope this helps.
Cheers Richard
tevake is offline   Reply With Quote
Old 10-05-2016, 12:30 AM   #7
1966 26' Overlander
Gridley , California
I am not totally up on diesel engines, but it used to be that the optimum rpm range was from about 1800 to 2300 rpm. This was (is) the power range, and is when the engine runs most efficiently.
To go along with this, at least 2000 rpm is best for an automatic transmission as it locks up and doesn't slip. Slipping creates heat which the trans cooler in the radiator has to try to dissipate. On a long hill, at low engine rpm and under load, the cooling system WILL heat up. Dropping down to the next speed range so the engine turns faster will definitely help.
The addition of an external trans cooler would help also, if you don't already have one.
By the way, the same goes for gasoline engines as well.
Iron Doc is offline   Reply With Quote
Old 10-09-2016, 08:47 AM   #8
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
When I owned the 2001 390XL with the Cat 330, it was plagued with constant overheating issues....a bad cooling system design to say the least. I changed the water temperature regulators (2) (thermostats), re-tensioned the water pump belt, simple greened the radiator and still had the overheating issue. The grill for the radiator is way to small and the hot air gets stuck up top because there is no way for it to get out. If you look at a 2006,2007 you will see that they have an additional grille above the one that the older ones don't have. In addition on my 2007 it has the 400 Cummins, which is much nicer. Also on the 330 Csts you have to buy or make on your own an oil breather extension kit to drop the oil breather tube down 8" or so, so that the oil doesn't get picked up by the fan and clog the radiator. Regards, Bob
bobmiller1 is offline   Reply With Quote
1st Trip, 1st Day, 1st Mistake BirdDog On The Road... 101 08-26-2016 03:10 PM
1st Big Trip, 1st Big Issues! trekerboy On The Road... 17 07-13-2016 07:07 AM
Climbing on the roof carver 1 Airstream Lifestyle 14 12-21-2013 11:35 AM
Cleaning and climbing on an Airstream!!?? Director Cleaning, Stripping & Polishing 6 10-12-2007 06:03 PM
345 Hill Climbing ViewRVs Mechanics Corner - Engines, Transmission & More... 12 04-18-2002 11:52 AM
