Old 01-13-2008, 04:43 AM   #1
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Northborough , Massachusetts
10 Yr. Old Cutter.....Now What
Have loved our Cutter for the past 10 years.
Has had ongoing maintenance, but this seems to be the year to really hunker down with a very aggressive maintenance schedule before camping season.
Following a winter trip from MA to FL, we found lots to do.
Has anyone relocated their fuse block from the front, somewhat exterior location to an interior location?
Our diesel has the fuse block up front and we have found that the road water and salt has really corroded alot of it. This resulted in a fuse catching fire on our trip. We also found water sitting inside one of the fuses.
A couple other upcoming projects;
Change all tires; Especially front two
Replace front step: Any source recommendations?
Check underside for corrosion
Review seals for any water leaks. Front passenger window seems to be a problem with water but can't figure out where it's coming from.
Check corrosion on propane tank
Another other suggestions?
Planning the next trip....
New England Unit....in Fun, Fellowship and Adventure.
Pam is offline   Reply With Quote
Old 01-14-2008, 02:05 PM   #2
John Brimer's Avatar
Send a message via AIM to John Brimer
Would like to see the result of the relocation of the fuse box. Also, instead of relocation, build a cover?
I have disassembled the front fuse box to fix a problem with one of the corroded fuse areas. There are a LOT of wires to be relocated.
I am on my third set of tires. Have over 118,000 miles on coach.
I would be glad to discuss maintenance with you.
While you are at the maintenance, look at the fuses in the engine battery area and the relays under the bed. The relays under the bed gave me problems when they were loose. Also, check the engine/air dryer for tightness. Mine was loose. I replaced it. Not too difficult if you are mechanically inclined.
John Brimer is offline   Reply With Quote
Old 01-14-2008, 02:24 PM   #3
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Wink Good advice
Hi John,
Great advice. I will let my husband know what we talked about. He's the one that is doing all the work. I think I might be the project manager.
Anyway. The idea was this....bring the whole thing inside. We talked about building a cover and had some ideas, but the whole winter travel thing is an issue with us coming out of New England in to the warmer climates in winter. So we had the idea to remove the tv, put the fuse blocks inside that area, build a cabinet door type of recessed facing and then mount a new flat screen tv to that. Then when we need to access the fuses we can open the tv cabinet. I really like the idea.
I believe Chuck is talking about rewiring quite extensively, while he's about the fuse block relocation as it makes sense to this all now.
I will send him the link to this thread....I am sure he has all the details.
Did you find any other corrosion or deterioration on the underside of your rig?
Have you added any kind of spare tire hoist system? That's on the wish list of things we'd like to add.
Old 02-24-2008, 06:34 AM   #4
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
It's working!
Husband, Chuck, is finishing up the redesign and move of the fuse blocks. Yesterday he finishing rewiring to the new fuses. HOORAY! It works! He's finishing up today and doing testing. I will get photos to publish, as I was most impressed by the whole project.
Even the woodworking and new flip up flat screen tv looks very good.
Old 02-25-2008, 02:20 PM   #5
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
Please post pictures !!!!
myfirstrv is offline   Reply With Quote
Old 05-24-2009, 01:26 AM   #6
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Fuse Panel Photos
Not sure if inserting the photos will work. But here goes.
Old 05-24-2009, 06:45 AM   #7
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
It's a keeper...
Okay, we are both on the same page and plan to keep the motorhome. We have so many upgrades now, including the next two...
1. Replaced the headlights with BMW headlights from our older 740 before we got rid of it. BIG difference. The factory headlights were quite poor and didn't give us much distance.
2. Replacing (as we speak) the tv antenna. Removing the Winnegard and replacing with a disk style boating antenna, which will be mounted to the mechanism that raises and lowers. We have just tested it and the reception is unbelievable! Huge improvement.
We have just found a local diesel mechanic to make house calls. He has met with us and has a list of parts to order for brake replacements, hoses, etc. It's perfect for us. He is working part time on the side from his regular fleet job.
Old 05-03-2011, 03:09 PM   #8
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
So how did the Mechanic, making house calls work Out ?
John H. is offline   Reply With Quote
Old 08-24-2011, 12:42 PM   #9
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Exclamation Improvements / Ideas......
I am looking at purchasing a 1999 Cutter and was curious what you've done since you started posting back in '06.... any great ideas or solutions to problems? Any comments about the Cutter overall I should think about?
GREENovaters is offline   Reply With Quote
Old 08-24-2011, 05:58 PM   #10
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
It went perfectly and was well priced. Very happy.
Old 08-24-2011, 06:03 PM   #11
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
We love our Cutter. It's comfortable and wonderful to travel in. The down side of anything is maintenance and repairs. I believe to own anything like this you either need to be financially well off or very handy. My husband can tackle just about any problem from mechanical to electrical to electronic. We are very fortunate.
We have had some leaking problems that are now being addressed with recaulking the roof.
There's some problems with hoses drying out, etc. that need to be watched. We did have some oil spray from the diesel engine that is being addressed with replacement parts.
Other than that it's just the usual stuff to keep things running. At some point we may want to simplify and change to a trailer and tow vehicle.
Old 03-23-2012, 02:03 PM   #12
1998 35' Cutter Diesel Bus w/slide
Laud by the sea , Florida
we have just purchased an identical unit to yours, 70K, and its a diesel.
have read all of your posts preparing for the delivery, you offer up some good shortcuts, thanks for posting!
mfancher is offline   Reply With Quote
Old 03-23-2012, 07:53 PM   #13
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Still love our motorhome. It is so comfortable and we love traveling this way. We are getting ready for some major maintenance starting this month to prepare for the season; recaulk the roof thoroughly, which means stripping it out first, rebuild the front bulkhead cabinet where some water leaked over time and did damage, and I believe engine and transmission maintenance. It's alot but it has to be kept up to date. Then we'll be ready for May camping.
Good luck with your new motorhome. I am sure you'll enjoy this as much as I.
Old 10-09-2012, 09:59 PM   #14
Registered User
1996 32' Cutter Bus
Petaluma , California
Images: 34
Just finished reading this entire thread. Wow, re-locating the fuse box must have been a real chore, but I understand. Out here where I live, I don't have to do any winterizing other than making sure all the tanks are drained and there's no snow or road salt. But, I am going to get a new fuse box and fabricate a cover for it sooner or later.... but, although there's some corrosion in there, it doesn't call for a complete relocation. Actually, there's no real amount of corrosion at all. I really like the Cutter 35. It looks good and if a slide has to be there, just one is more than enough for us. Enjoy!
AdamB is offline   Reply With Quote
cutter-32 ft. diesel. conniek Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 09-10-2007 06:01 AM
'98 Cutter Alternators Pam Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 11 02-10-2007 07:31 PM
1999 Cutter leak apetit Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 10-29-2004 08:35 PM
'97 Cutter 34' Lhill Airstream Motorhome Forums 0 06-18-2003 03:58 PM
1997 A/S Cutter 35 (DP) dleslie125 Airstream Motorhome Forums 1 03-30-2003 11:53 AM
