Old 10-11-2012, 04:50 AM   #15
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Northborough , Massachusetts
Lovin' Petaluma
Hi Adam,
Yes the fuse box move was huge! I couldn't believe my husband was able to do that and keep everything in order! It works perfectly in the tv compartment with the new flat screen in front of it.
We love the Cutter Diesel and do have the slide out. It is very comfortable. We did think about selling this year, as we have much less time for travel. Taking the year off we are now regenerated about getting out again next Spring. That gives time for updates, maintenance, etc. The mh is in good shape, but I would like to do some "redecorating".
We also have two trailers that need to be completed but that's on the back burner until Spring now.
BTW, we stayed in Petaluma at the KOA and loved the area.
Planning the next trip....
New England Unit....in Fun, Fellowship and Adventure.
Pam is offline   Reply With Quote
Old 12-04-2012, 07:01 PM   #16
1996 34' Cutter Bus w/slide
Grants Pass , Oregon
Anyone done rip in fiberglass?
Have a 1996 34' Cutter and did a stupid driving around corner of shop and hit the gutter. I have been using duct tape the past few years, but have been on a tear sealing roof with Dicor 502 and Eternabond 3" wide tape...all is going great but not sure how to fix tear in fiberglass. The easy way I thought would be to just cover hole with about 8" of Eternabond. Have looked at some posts of actually layering fiberglass on it and then painting. This coach is not beautiful and we decided it would be our last so we are doing lots of overdue maintenance. Just not sure of the fiberglass....any thoughts? Hope the picture makes it with the post
Name:	8 inches of torn fiberglass.jpg
Scott Mitche is offline   Reply With Quote
Old 02-14-2013, 09:19 AM   #17
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
How did you make out with this repair??
I would think you are lucky that it is confined to such a small area of the gelcoat f/g.
Any body/boat shop that has experience with f/g repairs should be able to make that look new for a reasonable cost. The decal looks unmolested, the location is above eye level, so a good gelcoat repair should be almost unnoticeable. To further disguise the repair you might install an upper side marker light on the repair after running a wire to the location before fixing it.
Sealing it from the weather is your first priority.
Dave
cutter-32 ft. diesel. conniek Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 09-10-2007 06:01 AM
'98 Cutter Alternators Pam Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 11 02-10-2007 07:31 PM
1999 Cutter leak apetit Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 10-29-2004 08:35 PM
'97 Cutter 34' Lhill Airstream Motorhome Forums 0 06-18-2003 03:58 PM
1997 A/S Cutter 35 (DP) dleslie125 Airstream Motorhome Forums 1 03-30-2003 11:53 AM
