Old 03-17-2013, 05:37 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Would you use your M/H with busted front air springs?
While under the beast changing fluids and filters, I noticed the front air bags inside the front springs were busted, and appear to have been busted a long time. The beast drove great bringing it home 350 miles and short runs around here. Would you go ahead and go on a trip with them that way?
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-17-2013, 05:53 AM   #2
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Granted my '77 is a far cry from your '92, but I had the bags replaced on mine when I found out that they were OE from GM. I've read that no reputable shop will do suspension troubleshooting or an alignment if the bags aren't functioning. There's a number of threads on here about how to replace the bags by yourself. I bought the parts, but in the end, despite being rather handy myself, I opted to let the local heavy-truck shop do the work. It was about $200 in labor (I supplied parts) and that included an alignment after the bags were replaced. The shop ended up taking the lower suspension arm loose from the knuckle which made bag replacement much easier. I think that if I would have attempted it myself that I would have likely spent a full day's time and likely had to purchase $50 in tools that I didn't already have.
WineStream is offline   Reply With Quote
Old 03-17-2013, 07:23 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Are you sure you have air bags in the front springs? Mine had plastic inserts inside the front springs that looked like a shattered airbag, but there are no air lines going to them. I thought that it was an air bag at first but it wasn't. AS only installed rear TAG axle air bags on my 92 LY.
92landyacht is offline   Reply With Quote
Old 03-17-2013, 09:11 AM   #4
WineStream's Avatar
2005 30' Safari
Images: 24
Yes, all of the "classic" motorhomes which are built on some variant of the GM P30 chassis had airbags inside the front springs from the factory (GM factory, not Airstream). The inflation ports, at least on mine, are installed on a body flange just inside the "hood". I would be surprised if they were still using that technology in '92, so maybe you didn't have them from the factory. If you have the service manual (chassis manual, not the Airstream manual) for your motorhome's chassis, it should tell you about the air bags and proper inflation pressure if the airbags were from the factory (GM). Perhaps someone installed aftermarket ones on yours and the inflator was at the bottom of the bag itself and didn't have lines running to a more convenient location.
I can't speak for tag axles or the suspension / airbags on them. I have no experience in that area.
Old 03-17-2013, 10:16 AM   #5
The front air bags, never had air lines going to them.
They were installed to reduce the front end bounce, and help with better steering control.
Airstream and Argosy motorhomes, all had rubber air bags within the front coil springs, never plastic.
They are supposed to be inflated to 55 psi, no more, no less, as per Airstream.
Traveling without them, is not a good idea.
Old 03-17-2013, 10:42 AM   #6
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Andy, speaking of airbabs. I just ordered a in line check valve from Inland RV, to stop my rear airbabs from losing pressure. Any idea where I might locate the old one?
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 03-17-2013, 10:47 AM   #7
It should be near the rear air bags.
Old 03-17-2013, 02:30 PM   #8
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Darn Andy, I was hoping I would hear a few "yea I drove mine with no trouble". But I value your opinion. Now I have one more thing to do before vacation.
Old 03-17-2013, 02:53 PM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I drove mine without air but before doing major repairs checked pressure in bags, 20 in one and 30 in the other, inflated to 55 pounds and major improvement in handling, postponed any improvements. Mine has the air fill tubes at the radiator, would be nice to have a gauge to see pressure but now check like tires for trips. I don't understand why you had a comfortable drive without bags, mine was awful, maybe it is the tag axles.
Old 03-18-2013, 09:51 AM   #10
2000 31' Land Yacht
Fort Erie , Ontario
Replaced my airbags with Hendersons Super Steer springs plus other front end pieces. The bags were leaking and handling was not very good. Had to replace steer tires due to feathering wear because the alignment was off due to the bags. After the alignment, ASLY sails real nice and no bags to worry about.
Steve
is.chowa is offline   Reply With Quote
Old 03-18-2013, 10:45 AM   #11
1992 36' Land Yacht
Grayson , Georgia
is.chowa: How did you decide which springs to get? Did you have the axle weighed? Thinking of doing the same with mine but don't know which set to get. Supersteer recommends weighing the axle first. Don't have a wiegh station near by me.
Old 03-18-2013, 10:52 AM   #12
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I ordered my air bags from chevy garage $140 each part#15631881
Old 03-18-2013, 02:02 PM   #13
1992 36' Land Yacht
Grayson , Georgia
I I don't get the new springs then this is what I was looking at:
Firestone Ride-Rite Front Airbags for Chevy and Workhorse P30, P32 Chassis
Any opinions on these?
Old 03-18-2013, 02:14 PM   #14
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I wish I saw those first
