Old 06-25-2013, 09:09 PM   #15
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Originally Posted by wvabeer View Post
Big C, I had a 78 31 ft LY and I used 12" square vinyl tile glued down with the edge of the tiles ran along the seams of plywood. This was done this way per Andy's suggestion for natural movement of the trailer. It worked and looked great for years.
Thanks for this. The guy we had look at ours has done a few Airstreams and othe rv's. I used to work for him back in high school laying carpet back in the early 70's. Precise, to the point. Going to replace some sub-floor (toilet area) as per other posts... Would like to do this myself, but no time. Least this way we can be on the road lots more quickly.
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 06-26-2013, 05:51 AM   #16
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
The piece that has rot I was going to replace. It is only aprox. 3' by 2', hopefully it isn't glued down.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 06-26-2013, 06:15 AM   #17
andreasduess's Avatar
1984 34' International
Toronto , Ontario
I delivered the new flooring for our trailer to our dealer yesterday - like others, I prefer to have a professional deal with this.
We went with a barnboard feel. Vinyl has come a long, long way. I swear I can't tell it from wood from three inches away. You have to touch it.
andreasduess is offline   Reply With Quote
Old 06-26-2013, 01:37 PM   #18
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
The wood floor is glued down. The floors are constructed just like the walls with 1.5" of blue foam insulation is glued to the floor pan and sub floor above. I used a circular saw to cut most of the outline. There are metal beams under the wood floor as well. You'll need to set the depth of the circular saw blade to the thickness of the wood in order to avoid cutting through the beams. I then used a small circular saw blade (about 1.25" in diameter) on a Dremel tool to make the final cuts perpendicular to the wall. If the wood is rotted, then the glue will have let loose. The areas that weren't soaked, still had a strong glue bond. I just used a large wide putty knife and hammer to separate the wood from the foam.
92landyacht is offline   Reply With Quote
Old 06-26-2013, 08:37 PM   #19
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Got our estimate today, $865.00 installed. Likely that there will be some subfloor work around the toilet, as we expected. Had budgeted 2-2500, so looks like we will come in way under our budget.
1975 Sovereign
"The Silver Bullet"
WBCCI #8578
Old 06-29-2013, 05:19 PM   #20
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
More progress
Should be done by tomorrow
ID:	189673   Click image for larger version
ID:	189675   Click image for larger version
Old 06-29-2013, 05:36 PM   #21
1992 36' Land Yacht
Grayson , Georgia
Looking good so far.
Old 06-29-2013, 05:49 PM   #22
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I installed FLOR carpet tiles...which I really like, but MAN some of these floors are just this side of gorgeous. I hated the stock floor as it looks cheesy and I found it almost impossible to keep clean. The FLOR is simple to install and you can pull up a tile and hose it off if you spill a whole plate of spaghetti on it (heh, heh), but now a gorgeous wood floor is VERY tempting....
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-01-2013, 04:04 AM   #23
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Almost done
Darn, this is a big project
ID:	189844   Click image for larger version
ID:	189846   Click image for larger version
Old 07-01-2013, 04:21 AM   #24
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Quote: "Darn, this is a big project"
Hats off to you. You did a great job. Good details on the photos.
Since we spend a lot of time in Florida, I was sure glad to get rid of our sand grabbing carpet.
Airstream12557 is offline   Reply With Quote
Old 07-01-2013, 04:32 AM   #25
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
In about 7/8 years we will be in the market for an other motor home and for sure solid surface floors are going to be one key item we will be looking for. Carpet is so nasty for camping, it collects everything. Now all I need is a broom.
Old 07-01-2013, 05:25 AM   #26
1968 20' Globetrotter
1993 32' Excella
Jax , Florida
I love the Allure maple vinyl plank flooring, I put it down in my '68, it looks very "real"- better than the real stuff to me, yeah, the gaps expand and contract a little(but so does real wood) but it's very durable, waterproof, easy to install, and easier replacement later if needed.
I installed 1/2 inch real maple planks in my '93, looks great, but they had to be glued down to the OSB(never coming up if needed?), so I worry about water damage, wear, and replacement.
I wanted to go with the Allure then, but it was just coming out at Home Depot and maple was special order and expensive.
luvoldstuff is offline   Reply With Quote
Old 07-02-2013, 03:54 PM   #27
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I think with the 1/2 gal. glue and 3 boxes of vinyl I had 120 in everything.
Old 07-02-2013, 04:58 PM   #28
1992 36' Land Yacht
Grayson , Georgia
Glue??? I thought the Allure flooring product didn't require glue and was a floating floor design. Did I miss something?
