Old 04-14-2009, 03:47 PM   #1
1992 36' Land Yacht
hubbardston , Massachusetts
Won't start
92 36FT LANDYACHT 454 GAS INJECTED
STORED ALL WINTER,,,WON'T START,,,TURNS OVER ,,NO SPARK
WHERE TO LOOK?????
KEVIN
kepko is offline   Reply With Quote
Old 04-14-2009, 05:53 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
in my era
I would have checked the coil. I guess you have an ignition module....start there. Good luck. Lots of really talented mecs here....they will help out.
Old 04-14-2009, 11:07 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
WHERE TO LOOK?????
KEVIN
Hi, is there a hidden kill switch under the dash somewhere?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-15-2009, 04:25 AM   #4
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Is it a good healthy crank when you said it turns over?
We have a Pace Arrow MH and it has an auxillary battery assist switch that allow juice from the house batteries to assist the engine better in starting when it's been sitting for a while. If yours doesn't have this, you could try jumper cables from a good battery.
Also, if it's been sitting all winter, check the gas tank - especially if it has been stored off site - might be empty. There's been a rash of gas theft from stored mohos because of gas prices.
You might also check the wires to be sure they are nice and tight and maybe replace the plugs?
Good luck - let us know how you solve it!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 04-15-2009, 07:19 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
WHERE TO LOOK?????
KEVIN
Ignition module, coil, rotor, ignition switch, fuses, fusible link, ECM.
First, check if the coil is getting power. Check to see if the coil is firing, if it is a remote coil. If not, go back to the fuses, fusible link, and switch. Mice love chewing wires.
If it has power, check to make sure the ignition module is getting power, then take a look at the rotor. They are cheap, sometimes corrosion can build on one and you won't see it. Replace it, and try again.
Old 05-14-2009, 03:42 PM   #6
1992 36' Land Yacht
it runs
ended up putting in new distributor for $140,,,old one looked like it came from the titanic,,all rusty,,purrs like a kitten
thanx
Where to Start WestMichCamp Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-27-2007 04:01 PM
a/c won't start Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-01-2005 09:57 AM
Where do we start??? airhead General Repair Forum 6 05-31-2004 07:58 AM
Where to start? stellablu General Repair Forum 0 08-08-2003 01:02 PM
where do you start?? skip General Repair Forum 6 07-20-2003 06:27 PM
