Old 11-06-2007, 10:37 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Winterizing 2003 LY (Gas) Question
I read the manual on how to winterize, especially the part that talks to the water heater. It doesn't say anything about the two hoses that come from the engine. Do I need to care about these rubber hoses?
While searching for my used LY, a 2001 model owner had a shut off valve installed on the hose going from the heater, immediately after the hose comes out of the heater. He said his mech did that to eliminate future problems , eg. ac will work more efficiently and his dash heater will put out more and hotter air.
I would appreciate all advice. Thank you.
Steve
spat61 is offline   Reply With Quote
Old 11-06-2007, 01:44 PM   #2
jimmickle's Avatar
2000 31' Land Yacht
Those hoses should not be a problem as they come from the engine and have engine coolant in them. (you do have antifreeze in the engine, don't you)
jimmickle is offline   Reply With Quote
Old 11-06-2007, 03:09 PM   #3
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
I bought a winterizing DVD from camping world, its easier to watch than read,
myfirstrv is offline   Reply With Quote
Old 11-06-2007, 05:39 PM   #4
spat61's Avatar
Jim,
Thanks for the response. I do have antifreeze in the cooling system. I just do not understand the reason for the hoses in and out of the water heater???
Steve
Old 11-06-2007, 06:21 PM   #5
myfirstrv's Avatar
Vermilion , Ohio
Might be your aux heat while your driving, maybe not enough to heat the water but might be to keep the unit from freezing ?
Just a guess
Old 11-07-2007, 12:56 PM   #6
gunworks's Avatar
1995 35' Land Yacht Diesel
Noblesville , Indiana
Steve,
I'm not sure how it works, but I have the same thing. What I do know is that while underway this system heats the hot water in the tank, because when we arrive at camp site after a full day on the road, Shazam! Hot water a plenty. Most times we don't even need to turn it on till next morning for shower, dishes, etc. I don't do anything more then drain the tank, shut off the fill valves (ie bypass the heater) , and then winterize with RV antifreeze (pink stuff. I fill through the water pump by means of installed bypass valve available at most RV centers. Don't forget to drain the icemaker if you have one. I have done this for four winters and have had no problems.
Good Luck
John
95 Landyacht
gunworks is offline   Reply With Quote
2003 22'CCD water pump winterizing rettoc625 Winterizing, Storage, Carports & Covers 3 10-07-2007 08:09 PM
winterizing question frederic.c01 Winterizing, Storage, Carports & Covers 14 08-30-2005 01:21 PM
winterizing question Stefrobrts Winterizing, Storage, Carports & Covers 11 11-03-2003 04:11 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
