Old 10-19-2007, 01:34 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Winter Questions
I have a LY AS (Gas) and live in Eastern North Carolina. It does not get bitter cold very often, last year we had zero snowfall. What is the jeopardy in not winterizing my tanks with antifreeze. Reason I ask is I would like to use the MH for short trips 3-5 days,during the cooler months. I could understand the need if I'm heading north. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 10-19-2007, 01:48 PM   #2
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
Going to different schools together...
In some respects Arizona is in a similar situation to the one you describe. Only occasionally does the weather get cold enough to freeze things. Last year it was 22 degrees in my back yard, where I store the Argosy, for 4 hours. The above ground domestic water pipes in the back yard were frozen.
My solution, which may not be mainstream, is to leave the power on in my shop which is connected to the shore power in the coach. I then leave the furnace on at its lowest setting. I make sure I have a full 30lb tank connected. The argosy has vents that go to the black and grey water cavities and the fresh water tank is inside in the front of the coach. This method worked fine for the above mentioned cold snap. I only leave the furnace on during periods where a freeze of more than an hour is expected.
Keeping the camper ready to fly is important because winter in AZ is when some of the best camping is available.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 10-19-2007, 01:50 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Hi Spat,
So long as the temp doesn't drop below freezing there is no problem. If the temp goes below freezing you can have water pipe damage, kill your water heater and tear up your faucets.
I suggest at the very least draining the system between uses and rigging the water lines to be blown out with compressed air. Damaged plumbing is no fun.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 08:07 AM
Winter is over azflycaster Off Topic Forum 19 05-04-2007 07:26 AM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter Storage guy99 Winterizing, Storage, Carports & Covers 11 10-11-2005 08:02 PM
Winter use ???? donnall General Motorhome Topics 3 01-08-2005 07:33 AM
