Old 04-26-2013, 09:23 PM   #1
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Lafayette , Louisiana
Windshield Wiper Arm Assembly
Anybody have a source for windshield wiper arm assemblies? My local NAPA truck parts store says they "might" could find one. My LY is a 2000 thirty foot.
jrkeef is offline   Reply With Quote
Old 04-26-2013, 10:04 PM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I got my wiper blades and arms parts from Rome truck Parts Inc. 706-295 4345
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 04-27-2013, 09:44 AM   #3
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Did you replace the entire wiper assembly? I took my passenger side arm and blade off. The hole in the arm that mounts on the protruding bolt is stripped as are the ridges on the bolt. The bolt only comes off, as far as I can see, with the entire articulating assembly. My local NAPA truck parts house says the entire articulating assembly with arms is about $300. Is that in line with your experience?
Old 04-27-2013, 10:50 AM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Check out this outfit.Wiper Arms | AM Equipment They have everything you need and if you wander around their web site you can learn more than you will ever need to know about wipers.
Cheers, Dan
~ Margaret Thatcher ~
Old 04-27-2013, 11:21 AM   #5
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Yes, I replaced both arms, wiper base,windshield sprayers, threaded acorn nuts etc. they were very knowledgeable. My wiper assembly is older than yours and they had everything I needed, so I'am sure they would stock the newer replacements as well.
Old 04-27-2013, 11:36 AM   #6
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Thanks Dan, I have sent them an email requesting a quote and ordering instructions. The assembly pictured on their website homepage looks exactly like the assembly I have. Thanks.
Old 04-27-2013, 01:36 PM   #7
Glad to be able to help. There are a bunch of great vendors around where you can source parts but AM Equip. has a great technical library. I redesigned my drivers side wiper and not only did I use the information on their site, but now I can actually ask for the part using the proper name.
Cheers, Dan
Old 05-29-2013, 07:38 PM   #8
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
I finally ordered a passenger side wiper arm from Bob Jones RV in Houston. In the process of doing surveys, drawing pictures and identifying my particular wiper assembly I learned a lot. Thanks to all for your input.
