Old 01-02-2011, 05:02 AM   #1
2004 30' Land Yacht 30 SL
Sarasota , Florida
Windshield leaks
I recently bought an '04 Land Yacht. The rubber gasket around the windshield has shrunk/dried out in the Florida heat. It's been caulked all around, and I keep at it, but still have some minor leaking. I'm wondering if I should have the windshield removed and new gasket put in or if that might make the problem worse. Do they still manufacture the original rubber gasket for the windshield, since the model is no longer made? I would appreciate advice from anyone who has had this problem and found a good solution. Thanks. George
geotraveler is offline   Reply With Quote
Old 01-02-2011, 05:39 AM   #2
George.
The windshields as well as the gasket and gasket lock, is still available.
Old 01-03-2011, 10:16 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Leak
George
Your unit is not that old. Try removing any caulk that is on it now, and after cleaning, tape with painters tape, apply a fresh sikoflex or other caulk.
Are you sure it is the windshield? If it has the Peterson marker lights, they tend to leak. They were made for verticle installation only. You can get LED replacements that are sealed to solve this problem.
Dave
Old 01-04-2011, 03:06 AM   #4
Sarasota , Florida
Thanks, Dave. I'm pretty sure it's the windshield gasket. I'll try resealing again, using the tape you suggested. Do you know of a good supplier for the LED replacements? Thanks again.
Old 01-04-2011, 10:47 AM   #5
masseyfarm's Avatar
Images: 56
Led
I use the painters tape just to give a neat edge to the caulk. You can work the caulk down into the rubber channel and not leave a big mess when you pull the tape off.
I just double checked the Peterson site and the replacement LED does not seem to be on their site. I got mine off ebay and I will try to look and see who the supplier was. They were exact replacements for the Peterson. I'll get back to you in a moment.
Dave
These are on Ebay now. Exact replacement for my Clipper marker lights.
3 Red & 3 Amber LED Marker Boat Trailer Truck RV Lights
Watch this item
Buy It Now$33.59Time left:22d 6h 12m
Item number:280608892282
Old 02-24-2011, 07:28 PM   #6
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
geotraveler,
We bought our 2005 ASLYG w/slide in summer, 2007. (Prior to that it spent a long time siting aroung and baking in the hot Florida sun.) Not too long after we got it, it developed a pretty brisk leak at the front end. I removed all of the tear drop shaped amber colored lights above the windshield, purchased new lenses and re-installed them with excellent results. Also re caulked where the front cap meets the cabin. A ton of work, but worth it.
Late last summer, I developed a very small leak from the top of the middle of the driver side windshield. So far, I have not diagnosed it. It is very small so I am taking my time with it. In the meantime, I am able to store it indoors, so when the weather breaks here in Michigan I'll get back at it.
Far and away, the worse problem was those lights. Have you made any progress yet?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 03-09-2011, 07:40 PM   #7
TerraYacht's Avatar
Castro Valley , California
My 2005 had a few surprise drips last year, and the tront leak was the clearance lights, both the caulking to the body and the lights themselves. I resealed to the body and its been fine since.
Also had leakage at the ends of my gutters: the directional gutter ends had broken off, probably a while ago, and the rain had eroded the sealant. I added new gutter ends and sealant, and so far I can knock on dry wood...no water inside where it shouldn't be.
TerraYacht is offline   Reply With Quote
Old 03-09-2011, 08:18 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
George,
Sealing a windshield is truly a job for a glass professional. After expending probably over a thousand tubes of sealant in the last 11 years as an RV tech, I think that I do a great job in the sealing department.
That said, when I had both windshields replaced in my Foretravel motor home, I realized that like anything else, some things are best left to the seasoned professional!. There is a definite sequence of events to follow and specialty tools that are required. Slapping a little sealant (and BTW, as good as SikaFlex is, they used another specialty polyurethane) on your gasket will NOT LAST!
Since you are in Florida, I can very highly recommend D & K Enterprises of Clearwater, FL. They did a most superb job in replacing and especially sealing the 2 new windshields. Their technique was flawless and of course, there are obvious tricks of the trade that only guys like this know! I watched the entire process and was totally impressed! PM me if you would liker their contact information.
Old 03-10-2011, 07:11 AM   #9
Originally Posted by lewster View Post
George,
Sealing a windshield is truly a job for a glass professional......
That said, when I had both windshields replaced in my Foretravel motor home, I realized that like anything else, some things are best left to the seasoned professional!......
Lewster, thanks for speaking up. I'm curious, at what point did you decide to replace your windshields? Were they cracked? Leaking a little? Leaking a lot?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 03-10-2011, 08:28 AM   #10
masseyfarm's Avatar
Images: 56
Leaks
Many times the windshield gets blamed for a leak that may come from something leaking further back on the front cap or roof itself.
Look for access to the insulation above windshield, ie: TV antenna mount, or Sat. dish mount, and above the front side windows, and check to make sure it is dry above and back of the windshield.
Again, some of the marker lights ( Peterson style) act as a tray and collect water that eventually will follow the wire inside. Some leaks as far back as the skylights will travel along the one piece f/g roof and exit at the front or rear cap area.
If the windshield proves to be the problem, clean and recaulk with the same polyurethane that the glass experts use. This will last another year or so and can be redone as needed.
If you want to re and re the windshield, I would do an ALASKA Highway trip first and then know you have a reason to do it.
Nothing worse than water where it is not wanted.
Dave
Old 03-10-2011, 08:32 AM   #11
lewster's Avatar
Both were cracked on the way back to FL from OR this past fall. Errant little projectiles from a work truck ahead of me peppered both sides with BB-like craters.
Old 03-10-2011, 12:30 PM   #12
Bummer, did your insurance cover replacement? And how's the fit and finish of the replacements?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 03-10-2011, 07:10 PM   #13
lewster's Avatar
Oh yes!
Covered under comprehensive for $250 deductible. Seems that at least one had been replaced before, so I gave the glass company the numbers from the better fitting side, along with a set of measurements that they wanted.
Both fit like a glove and they look like new!
Old 03-11-2011, 11:53 AM   #14
Oh yes!........
.........Both fit like a glove and they look like new!
Sounds great. Thanks for the info.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
