Old 12-11-2011, 08:57 PM   #15
TRfour's Avatar
Grand Prairie , Texas
Post Another View
It is not uncommon that the AirStream factory had an overstock of 30 AMP wiring harnesses. You know, the more you buy can help to keep overall costs down. They just got caught in an flip of the switch to 50 AMP service, and could not absorb losing what was already in stock.
My photo album; http://www.winnipesaukee.com/photopo...e=22&ppuser=83
TRfour is offline   Reply With Quote
Old 12-12-2011, 08:46 AM   #16
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by 92landyacht View Post
I still think the major issue is in doing the cable runs. Replacing breaker boxes and transfer switches are easy. It's simply a matter of disconnecting and reconnecting the connections to new components and maybe modifying the openings for the additional components. Replacing the main shore cable is a given. Adding the new wires, IMHO, is still the biggest issue. This is coming from 20+ years experience in doing industrial wiring as a controls engineer. I figure, if I can do a new production plant with 480V 3-phase, I can do a simple 120/240 single-phase design. The genset that comes in a 92 LY is a 7KW unit. For AS to install a 30amp system simply makes no sense since the genset can easily pull 48amps continuous. I just wish AS had made it easier to add additional wires without having to resort to running them under the unit or disassembling the ceiling.
As I mentioned before, *if* your main breaker box is wired for 240-volts (i.e., the 2 x 120-volts output from the genset), then the only modification is to redo the ATS switches. I have offered to email the schematic which we used to anyone who PM's me.
In my case, the only cost was the new shore cable and plug (I did have a faulty time-delay relay which I was able to source and replace for $10).
Granted, not all AS motor homes are wired alike, but the schematic, which really is a redesign of the ATS switches from 2 30-amp ones into a single 50-amp one using all the existing components without the need for any additional ones, can be used as a starting point. For someone who has either an electrical engineering background or certified electrician, it should provide a starting point.
If, on the other hand, the shore power, main breaker box and genset are all 30-amp 120-volt, then running additional wiring would be required, and that can be a major undertaking.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 12-12-2011, 10:12 AM   #17
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by crazeevw View Post
just have never needed 2 A/C's just yet to know if I'll make the attempt. If I can find the thread, I'll post the link here next.
Thanks, Derek
Would be appreciated, down here in the deep desert, come April, we could use THREE roof airs!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-12-2011, 04:47 PM   #18
2000 31' Excella
Ontario , Canada
Thumbs up
Well crazeevw that is what I was thinking in my previous post. The second 30 amp cable is fairly inexpensive and could be hooked up to the 50 amp connection on the post with a 30 to 50 amp pigtail. (you could use one of your extra 30 amp extension cords.) You wouldn't need to have both a/c running unless it was 95 in the shade. And how often are you really hooked up to the genny anyway.
In my previous post, I questioned the 12v requirement but now know that the fan runs on 12v. If my approach to this is valid (still in doubt) then you wouldn't need to fish new wires thru the ceiling to the a/c.
So why won't it work?
woodytwo is offline   Reply With Quote
Old 12-12-2011, 08:32 PM   #19
Grain Valley , Missouri
This may be the link crazeevw was looking for. It is a fairly simple procedure to wire in a separate plug for the second air.
RV.Net Open Roads Forum: How to run two AC's with 30 Amp Service UPDATE UPDATE
QuietWater is offline   Reply With Quote
Old 12-13-2011, 06:27 AM   #20
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
When we purchased our LY we knew nothing about 30 amp/50 amp service & running the ACs. Our first night in the LY was in hot, humid Florida. When the bedroom air wouldn't start we called the dealership & asked what the trick to turning it on was. We were asked if the front air was running..."yes, it's the bedroom AC that won't start." (We had been shown during the 10 minute walk-thru that it worked.) We were then given this sequence to running both ACs. 1) start the front AC, run on high, get things cooled down. 2) Turn front AC down to low setting. 3) Turn back AC on low. 4) Chill.
This seemed to work. Both Acs were running. Then at some point the front AC turned off. By this time we were sleeping & cooled off... Sometimes ignorance is bliss...just hope this wasn't potentially harmful to the electrical system. We have very few times when 2 AC's are needed. But, I always thought we could use this start-up sequence if needed. Maybe not such a good idea.
Schools Out is offline   Reply With Quote
Old 12-13-2011, 06:39 AM   #21
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
On my 92 LY there's a switch in the kitchen cabinet that switches power from the front to the back AC. No way to run both at the same time since only one can get power at a time. Just seems strange that they would install a genset (7KV) that can provide 48 amps of current when the breaker box can only support 30 amps. Why didn't they just install a 5.5KV genset and save the money?
92landyacht is offline   Reply With Quote
Old 12-13-2011, 09:03 AM   #22
2000 31' Excella
Ontario , Canada
Thumbs up
Quietwater, that was a great link. The information is very well described and with great pictures.
Much appreciated and thank you.
Bill
Old 12-14-2011, 07:39 PM   #23
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Check this link out, only one I could find so far.
Thanks, Derek
http://www.airforums.com/forums/f311...ion-20737.html
Old 07-11-2013, 09:15 PM   #24
1994 31' Legacy 30
Originally Posted by blkmagikca View Post
I had had a '94 LY diesel pusher that came with 30 amp shore power. I had a friend redesign the schematic using the 2 existing ATS switches to work on 50 amp. Prior to finalizing the design, he checked with CSA to make sure that the changes would comply. The interesting thing is that you don't need the massive cable used for 50-amp, because you are still using 30-amps, but at 240 volts. The wire gauge is unchanged. While I sold this motorhome, I still have a copy of the revised schematic and will email it. Just message me through this forum with your email address.
As an addenda, with the 6.5kW genset, the house main panel did not need replacing or modifying. The sole modification was to rewire the 2 ATS switches to function as a single one. The original circuit had the neutral being switched - this was not necessary (as per CSA) so the existing relays were sufficient. The shore cable needed to be replaced from 3-wire to 4-wire, but the same gauge.
Can you still send the revised schematic? I have a 30' 94 LY, Gas, but the wiring should be similar. My email is ctayers1@verizon.net.
ctatoday is offline   Reply With Quote
Old 07-12-2013, 09:12 PM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
See: http://www.airforums.com/forums/f312...x-92524-2.html
and
http://www.airforums.com/forums/f160...tml#post220114
The schematic is also uploaded.
Name:	City power circuit.jpg
VE3JDZ
AIR 12148
Old 07-14-2013, 05:49 PM   #26
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Search through the Classic Motorhome section. Someone has a detailed write-up of how to run the 2nd A/C unit while still having only a 30amp hook-up. Basically, it involves disconnecting the 2nd A/C (usually the rear) from the existing wiring, and running a separate power cord just for the 2nd A/C. It's fairly simple, by the way I read it, just have never needed 2 A/C's just yet to know if I'll make the attempt. If I can find the thread, I'll post the link here next.
Thanks, Derek
The PO did this to my M/H I have never tried it but was told it cools fast using shore power. and my manual says the generator will run both a/c's but only will run.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Yay! 50 amp Service upgrade - Done yve79 Batteries, Univolts, Converters & Inverters 34 10-25-2012 07:23 PM
2008 Airstream Classic 31! 50 Amp Service, 2 AC Units! eBay Watch Airstreams on eBay 0 08-30-2011 08:20 PM
3 Amp Availability gaylejoe WBCCI Forum 27 08-06-2011 03:38 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
