Old 04-09-2013, 05:36 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
What to patch the roof holes with?
I am removing the box on my rear roof. What should I use to patch the holes.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 04-09-2013, 07:44 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have not used these products, but one of them might be part of your solution.
RV Leak Repair Tapes & Sealants | EternaBond
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-09-2013, 07:57 AM   #3
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I am not a fan of Eturabond,but will try it as a last resort
Old 04-09-2013, 07:57 AM   #4
Vulkem sealer, is the extremely long lasting very durable sealer.
Old 04-09-2013, 08:01 AM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Sure is! (I know. I'm trying to remove some of it in preparation for polishing.)
Lynn
WBCCI 21043
Old 04-09-2013, 08:26 AM   #6
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
The roof is fiberglass, so you could just use fiberglass mat and resin to make the seal as perminant as the original roof. Just make sure there's no sealant around the holes (need to do this no mater what you do) and scuff up the area. A small section of mat fiberglass and brush on some resin with hardener and your done. If done right, theres no chance of leakage.
92landyacht is offline   Reply With Quote
Old 04-09-2013, 10:16 AM   #7
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I am eventually going to remove all of that Eturnabond. Does anyone have a suggestion on what to use for that?
Old 04-09-2013, 02:17 PM   #8
1992 36' Land Yacht
Grayson , Georgia
Why the descision to remove the Eternabond? No fun removing all the Eternabond if it's stuck down right. Just removing a few inches too a fair amount of time using heat and an X-acto knife. If it comes off easily, then it never was stuck down correctly.
Old 04-09-2013, 06:15 PM   #9
1971 29' Ambassador
guyton , Georgia
big hammer and cold beer
r.swanson is offline   Reply With Quote
Old 04-09-2013, 07:35 PM   #10
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
If it were only Friday.
Old 04-11-2013, 08:58 AM   #11
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I am going to try the fiberglass resin/mat repair after removing the box this evening and hope this will end my leaks
Old 04-11-2013, 09:40 AM   #12
1992 36' Land Yacht
Grayson , Georgia
Hopefully the box is the source of the leak and sealing the mounting holes after removing it will fix your problems. Exactly where are you seeing water inside the cabin? I thought your original water leaks were seen at the front.
Old 04-11-2013, 09:55 AM   #13
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
in the back corner cabinets on each side of the rear its been leaking.
Old 04-12-2013, 05:50 AM   #14
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Check the seal/seam between the roof and the molded end cap on the MH. Pick at the seal material to make sure that there is a good bond. That area, both front and back, needs to be checked often to prevent water intrusion.
Sam
Airstream12557 is offline   Reply With Quote
