Old 04-12-2013, 06:55 AM   #15
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Agreed with Sam. The end caps need to be inspected along all seams. That includes from the roof all the way down the sides. One area especially prone to leaking is where the end caps meet the roof corner rounds.
92landyacht is offline   Reply With Quote
Old 04-14-2013, 12:09 PM   #16
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
What do you think?
Before and after fiberglass mat and resin
ID:	183330   Click image for larger version
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 04-14-2013, 02:47 PM   #17
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
A/C and bathroom vent not too far away, I found when I replaced the vent for bathroom there was one leaking screw, had rust and wood was damp, caulk applied over screws around perimeter of vent looked good but allowed water to penetrate. For back corner closet leaks, end cap is best bet at the turn from roof to side.
Old 04-14-2013, 04:51 PM   #18
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Only 3 of the 6 screws that held the box down were not rusted 2 were really thin , I expect that is where a leak was. I also removed all of the Eturnabond, that tape held water under it. I am so glad I removed it and applied Dicor to the seams and screw heads. That tape seams to stick to painted aluminum and smooth fiberglass really good but not the pebbly texture of the fiberglass roof
Old 04-20-2013, 01:37 PM   #19
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Wow and the Eturnabond company is refunding all my money I spent on two rolls that I removed from the roof.
Old 04-20-2013, 08:35 PM   #20
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
What did you do? Just contact them and tell them you were disappointed with their product? Dicor offers a product to clean fiberglas roofs and an Elastomeric sealer if you are happy with their products.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 04-21-2013, 05:38 AM   #21
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Yes, I called the makers of Eturnabond and they ask me a bunch of questions and decided I installed the tape correctly and want the old that I peeled off. I am glad I removed that stuff there was alot of moister under the tape that was corroding the rivets. They are giving me a full refund excpt for the roller and shipping.
Old 04-21-2013, 01:01 PM   #22
1992 36' Land Yacht
Grayson , Georgia
Just a word of caution. Moisture under the tape means you still have water soaked wood that needs to dry out. The tape will not only keep water from getting in, but also keep moisture from getting out. When I repaired the walls on my LY it took weeks for all the moisture in the remaining walls to evaporate before I could seal everything.
Old 04-22-2013, 10:00 AM   #23
1975 Argosy 26
West Chester , Pennsylvania
I suspect a leak around the A/C unit. It's covered with a tarp now, so I can't really see, but I'm wondering if the unit is self contained, with only tubing penetrating the
roof area? Any comments about leaks in that area?
Thanks, Reginald
Reginald is offline   Reply With Quote
Old 04-22-2013, 10:50 AM   #24
1992 36' Land Yacht
Grayson , Georgia
There would be a square cutout and a seal between the top unit and the roof.
Old 04-22-2013, 03:53 PM   #25
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
Like Landyacht said there is a big square hole and on mine you can look thru the filter hole and see if it has been leaking.
