Old 08-22-2012, 02:40 PM   #1
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
Water pump filter Part Two
Since I had it apart to clean out the plastic pieces (earlier post) and I thought the inline filter was a pain to get out/reinstall in such a tight area, I found an improved filter that will stay in place when the filter media (screen) needs to be cleaned. Installed a three way valve to siphon rv coolant if the need comes to winterize. Attached a picture of the old filter
ID:	166442   Click image for larger version
JMSx2 is offline   Reply With Quote
Old 08-22-2012, 08:48 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Wow, that is a tight space. Mine is located under the foot of the bed and can be accessed by a fold down door that opens toward the hallway in front of the bathroom and shower. I don't see a door on your compartment. Where is your pump located?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 08-23-2012, 07:44 AM   #3
JMSx2's Avatar
Belgrade , Montana
The pump and access to the drain line valves are underneath the bed between the water tank and the 110 breakers. The fold down door to the hall under the bed gives me access to the breakers only.
Old 08-24-2012, 03:05 PM   #4
JMSx2,
From your photo above, it looks like there is a thin wall between the pump and electrical areas. My pump and breaker box share the same area forward of the water tank. It looks as if you could easily remove that partition and have much easier access to your pump.
Also, I moved the breaker box to the right side wall so as to open up space to service the water system. (there was enough slack in the wires to move it without having to take the breaker box apart.)
Additionally, I unscrewed the part of the bed board by the foot of the bed and put hinges on it so that it can flip up under the foot of the mattress, again to improve access to the compartment. I'll try to get a photo to post.
I hope I haven't confused you too much.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 08-24-2012, 04:54 PM   #5
JMSx2's Avatar
Belgrade , Montana
Like your idea about installing the hinges and not have to deal with the six screws holding down the board covering the area. Don't think I have enough wire cabling but I'll take a look. Thanks for your ideas!
