Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 07-18-2014, 05:03 PM   #1
1998 31' Land Yacht
Lake Odessa , Michigan
Wink Water Line Valve Repair
I have a 1998 Land Yacht P30. The water supply valves are leaking and I need to replace the rubber washers. I can't seem to find the correct size. Does anyone know what size of washer I need?
btuinstra is offline   Reply With Quote
Old 07-18-2014, 06:53 PM   #2
Registered User
1996 32' Cutter Bus
Petaluma , California
Images: 34
This happened to us too. I don't know what the size is. I just removed one of the old ones and brought it into an rv parts store. The size is not carried at regular hardware stores. Buy at lest 10-15 of them. They are also on the water pump, toilet, faucets and other water valves and they'll all go bad sooner or later.
AdamB is offline   Reply With Quote
Need to repair water line, suggestions? jrussjr Fresh Water Systems 6 02-14-2014 09:42 PM
Propane Line quick release valve set up fmacmaster LP Gas, Piping, Tanks & Regulators 1 03-27-2013 07:31 AM
grey water valve repair john hd Waste Systems, Tanks & Totes 33 12-21-2010 04:30 PM
Unknown water line valve- 2005 Classic Wingeezer 2001 - 2005 Classic 21 11-23-2010 03:02 PM
Line Drain Valve replacement jcramer Fresh Water Systems 2 08-03-2010 09:13 AM
