Old 07-05-2015, 06:02 PM   #1
2000 31' Excella
Ontario , Canada
Unhappy water leak at shower fan
Hi to all.
Here is another source for roof leaks that sure surprised me. I needed to clean the screen in the roof fan in the shower on an A/S land yacht 30 M/H. had to remove the screen which is dedious. But discovered deserted nests form bees or some other flying pests in the foam bead insulation. I asume that they got in when the vent was open. Also discovered that if you leave your shower vent open when it rains that water can get in, leak along the luan and drain in your closet which is next to the shower. Seems like when they installed the vent that the piping was too short leaving a gap. So close the vent when not using the fan is the recommendation.
woodytwo is offline   Reply With Quote
'06 Safari FB Water leak from Shower Drain RichHog Sinks, Showers & Toilets 0 09-01-2014 03:35 PM
leak in water pipe under shower tray Annikins212 Sinks, Showers & Toilets 3 06-13-2014 03:56 AM
HELP! Water leak In 2005 Safari 28W Coming from behind shower? Shirley C Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 12-30-2012 06:51 PM
Water leak in the shower wall gwteale General Motorhome Topics 2 06-24-2004 06:46 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
