Old 01-23-2016, 08:14 AM   #1
tw369's Avatar
1997 31' Land Yacht
greenfield , Indiana
Using the shore line
Hello,
I have a 1997 Land Yacht Thirty. I just bought it and I am trying to learn how everything works. When I plug in the shore line I don't have power in the motorhome unless I turn on the battery switch on. Is that how it works?
tw369 is offline   Reply With Quote
Old 01-23-2016, 08:18 AM   #2
dznf0g's Avatar
Oswego , Illinois
My Classic trailer is wired that way.
I assume you're talking 12V power.
-Rich-
Old 01-24-2016, 10:52 PM   #3
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
I have a 97 LY diesel pusher. The battery switch I assume your talking about is near the side door. Off position kills power to the coach batteries so nothing will drain them down and mostly used for storage periods. Anytime your using the RV leave this switch ON.
Did you get the owner manuals with the RV? If not, checkout out the Airstream factory website and many of those can be downloaded. I have both the diesel and gas 1997 manuals. Will be glad to look up anything you might have questions about.
Mike1997 is offline   Reply With Quote
Using a 30A cord with a 50A shore power terminal thebreezeman Electrical - Systems, Generators, Batteries & Solar 46 02-08-2015 07:12 PM
Bambi battery not charging from shore line nbranco Batteries, Univolts, Converters & Inverters 13 07-23-2013 05:05 AM
Replace fixed shore line with removeable pickerdd Electrical - Systems, Generators, Batteries & Solar 3 10-12-2009 01:39 PM
Using shore power w/o batteries 1989 Excella 1000 GAPeach Batteries, Univolts, Converters & Inverters 4 12-29-2007 09:58 PM
Need to find adaptor to go from this outlet on my generator to shore power line in AS wacnstac Generators & Solar Power 11 04-27-2006 11:49 AM
