Old 01-04-2008, 08:18 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Two Switch Boxes
I have a 2003 Airstream Land Yatch that I bought used. I'm trying to stay ahead of problems while underway by educating myself on things that could go wrong. But, I can't find the two 110V switch boxes that are plainly descrived as being in the trunk per the manual. They are not there. Can someone with my model help me locate these? This is the exact quote from the manual:
"110-VOLT SWITCHOVER BOX
To protect linemen from an unexpected shock the generator must: be wired through a switchover box. Two
automatic switch over boxes are located in the trunk storage area behind a false panel on the roadside of the
area."
Thank you.
Steve
spat61 is offline   Reply With Quote
Old 01-04-2008, 11:23 AM   #2
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
Steve,
Which model 26' 30 or 33'?
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 01-04-2008, 01:32 PM   #3
spat61's Avatar
Two Switch Boxes
I have the 2003 30' model. Thank you.
Old 01-10-2008, 07:47 AM   #4
1968 17' Caravel
Images: 79
Steve,
There is a false wall located on the Curbside of the motor home that will hinge out to gain access to the switch box. He said Airstream had it wrong in the owner’s manual and there is a junction box on the roadside where the power cord comes in. From there a wire is run to the curbside to another box behind a false wall.
Old 01-14-2008, 07:35 AM   #5
spat61's Avatar
Found the Switch Boxes
Patrick,
They are right where you said they would be but you would never know they are there just by looking at the wall. Thanks.
Steve
Two Metal Boxes on extended bumper? Is this factory? Aluminumb Buyer Guidelines 9 09-12-2007 05:26 PM
Battery and converter boxes? erock53 Batteries, Univolts, Converters & Inverters 2 05-05-2007 10:43 AM
Topper or boxes? Cracker Tow Vehicles 8 02-02-2004 08:52 AM
Plastic battery boxes ! 77caravaner Electrical - Systems, Generators, Batteries & Solar 1 10-07-2002 12:57 PM
