Old 08-04-2009, 09:46 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Two 12V vs. two six volt batteries
I have a 2003 LY (gas) 30' and coach batteries need replacing. Would I mess things up if I used two six volt golf cart batteries? Or should I stick with two deep cycle 12 Volt RV batteries. Also, has manyone mused the Energizer Brand SAM's Club sells? I don't do very much dry camping. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 08-04-2009, 10:12 AM   #2
SteveH's Avatar
Common Sense , Texas
If you installed two six volt batteries, the first thing you would have to do is rewire the system because the two 12's are wired parrallel, and the two 6's would need to be wired series.
Then, if the two 12's are 50 amp hour batteries, to get the same capacity out of two 6's, they would have to be 100 amp hour batteries, and would probably be more expensive.
Old 08-04-2009, 10:53 AM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
Two 6 volt Golf Cart batteries will give you more available Amp Hours to run your stuff while boondocking...
10 inch 12 volt (group 24) has about 80 Amp hours x two batt's = 160 AH
12 inch 12 volt (group 27) has about 105 Amp hours x two batt's = 210 AH
(2) 10 inch long, 6 volt GC (group GC-2) have about 225 amp hours total when hooked in SERIES..
GC batteries are taller, so you'll need about 2 inches more space..
Wiring two 6 volt GC is no big deal, as you'll use one wire between the POS of one battery, and the NEG of the other which is SERIES wiring - to give you 12 volts you'll need...
You're two 12 volt batteries are wired in PARALLEL, which is POS to POS, and NEG to NEG on both batteries...
SERIES wiring will add the voltage of the batteries together, but the AH rating remains the same as one battery...
PARALLEL wiring will add the AMP HOUR ratings of the batteries together, but the VOLTAGE remains the same as one battery...
If you don't do much boondocking, and your existing type 12 volts have performed fine when you did, I really don't see much cause to change to the 6 volt GC batts...you probably won't see any more life in terms of 'years' of service with the GC's...
If you do intend to do more boondocking, then the GC's will allow you to run your 12 volt stuff a bit longer than the two 12 volts...
GC's are a great battery for RV use, but not all that important if you don't really need that extra capacity...as compared with the 12 volt deep cycle batteries, that is...
Ray & Pat; Morada, CA
Old 08-04-2009, 11:33 AM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Ah, the age old question: which battery is better? I've used both over the years and I have to say that Golf Cart batteries are superior to regular 12v, Size 27 batteries. They're beefier (each weighs 62 lbs), provide more amperage, and generally last longer than regular Size 27 batteries.
I used to use Trojan T105 Golf Cart batteries but they're $135 each. Saturday I bought two Golf Cart batteries from Costco for only $75 each. I'll give them a try but friends say they are just as good (and heavy) as the Trojan T105s.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-04-2009, 11:43 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't want to muddle things up but there is a 3rd choice. A larger battery could be put in. I have a 4B AGM which gives 200 amp hours there is a bigger size I think it is 8B which I think is about 300 amp hours. The 4B was cheaper than buying 2 separate batteries although I did have to make room for it.
Old 08-04-2009, 11:59 AM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
How much are they and how much does each battery weigh? I've been told the AGM don't do well in the AZ heat. Don't know if that's true, but since I've been happy with the Golf Cart batteries, I'll continue to use them.
1958 Overlander
4CU 1st VP
Old 08-04-2009, 12:18 PM   #7
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
They are called 8 D batteries used one for years great batteries just hard to handle because of size have went to the 4D battery easier to handle.have been happy with its performance.we have always called 8D could be wrong and they are 8B?
Gypsy Jo is offline   Reply With Quote
Old 08-04-2009, 02:16 PM   #8
BDandTTs's Avatar
2005 22' International CCD
Phoenix , Arizona
Images: 49
Spat 61,
Since you said, "I don't do very much dry camping," there is no reason to increase your amp hour capacity, nor your draw down %. Go with the less expensive 12V batteries.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 08-05-2009, 02:40 AM   #9
2005 19' Safari
GLENDALE , AZ
Quote: "I've been told the AGM don't do well in the AZ Heat."
FYI, we replaced the two OEM batteries with Optima Blue Tops when the OEM batteries failed after only one year. The Optimas have worked well for the past three years. However, we installed a marine battery switch that allows the selection of Battery A only, Battery B only, A+B, and both off.
We only charge overnight, once a month; and the batteries are set to OFF the rest of the time, except when we are on the road. I think that not leaving the batteries to cook 24/7 has contributed to their longevity (so far).
Also, we only use one battery at a time, and save the other as a backup when we dry camp for several days. This works well if you overnight somewhere with hookups a couple of times a week, or if you are on the road every couple of days. And, so far, we haven't needed a generator.
Old 08-25-2009, 01:39 AM   #10
DubleDeuce's Avatar
1982 31' Airstream310
Lilburn , Georgia
Something for everyone-
BCI Battery Group Size Chart
This is a list of the more common battery BCI sizes. These are DIMENSIONAL sizes ONLY and NOT capacity ratings.
Looking down low on the list you will see the 4-6-8D size batteries. The 8D is truly a bear of a battery and weighs in (depending on the amp hr rating) at 75-90 lbs.
As to WHICH battery is the "best" is like starting an argument about Fords and Chebys.
The key to the selection process is essentially like filling up at a gas station. With gas you are buying gallonage. With batteries you are buying electrons. The more of any item you buy, the more it will cost you.
There really is NO such thing as battery A being 'better' than batter B. At least not from a quality standpoint. Batteries are batteries. The REAL issue is CAPACITY. And here again there are many ways to measure. The STANDARD definition of battery capacity is the AMP/HR rating. There are other rating to be sure.
If you are buying a battery to crank your gas/diesel engine you would use the automotive standard of CA or CCA. CA stands for Cranking Amps and CCA stands for Cold Cranking Amps. The DIFFERENCE is the two ratings is significant. The CA rating is the amount of current (in amperage) that a battery will deliver at an ambient temperature of 32 degrees F and not have the terminal voltage drop below 9.7v The CCA rating is the amount of amperage that a battery will deliver at an ambient tempreture of 0 degree F and not have the terminal voltage drop below 9.7v.
Obviously, the CCA rating (IF BOTH ARE EQUAL IN NUMBER) is more desirable as it will provide MORE cranking power at a lower temperature. It is often the practice of the battery saleman to SUBSTITUTE a CA rating (higher in number) when the buyer specifically requests a CCA rating in order to compete on price. The SAME rules apply to batteries as to any other commodity-you get what you pay for, and if you are NOT careful, you will not get even that.
Automotive batteries are NOT suitable as "house batteries" as they are designed for EXTREME amperage draw in short bursts of time. House batteries are of a different design internally and are designed for slower discharge, longer discharge, and deeper discharge. An automotive battery subjected to a deep discharge (to 0 terminal voltage) will be irrevocalbly damaged and in many instances, distroyed, while a deep cycle battery will not be the worse for wear after many such discharges.
6v or 12 volts? What to do? Generally speaking a 6 volt battery (as many as you need to meet minimum demand) will work better that a 12 volt. This is so only because of the ability of the manufacturer to place MORE, and thicker, lead plates into the 6 volt battery case that they can in a 12v battery case OF THE SAME SIZE BCI class.
Newer battery technology has been hard at work recently putting old battery technology on the back burner. GEL batteries, waterless batteries (low/no maintenance) and closed system style batteries are all making a grab for the conventional flooded cell (the kind that has been on the market for some 80 years) type we are used to buying. The primary attempt at the new designs is to get away from the single problem of flooded cell technology, the water/electrolyte issue. With water as the starting eletrolyte of all flodded cell technology, it must be replenished as the battery goes through its normal cycle of discharge and charge. The charge cycle also is responsible for the production of free hydrogen in the cells. If the hydrogen disipates into the atmopsphere, all is well and good but there is still a chance that an overcharge or short will cause the hydrogen gas to ignite with often disastrous results. If you permit a batterys electrolyte to drop below the tops of the cell plates, damage and short life is the result. So, batteries must be maintained AND they are a safety hadzard.
To the rescue-the sealed battery. No water, no gas, NO problem. WRONG?
Even though the manufacture will tell you that the unit is sealed for life and needs no regular maintenence, it is JUST as possible for a new type battery to fail and for the SAME reasons. Overcharge and loss of electrolyte. Only NOW you can't as an owner, do anything about it except buy a new unit.
The GEL battery technology is essentially a hybrid of the no maintenance unit and and a totally SEALED unit. The electrolyte is actually a gel like material and is ROLLED up inside of a special lead grid like a jellyroll and stacked upright like a D cell battery into a plastic battery (BCI Class) case, 1 cell = 2v, 6 cells = 12Vs'. They had their problems early on as the gel would continue to separate under extreme loading and render the battery useless. The hotrod crowd likes them as they permit long term storage (but NOT long term life) without outgassing and causing battery corrosion and a cleaning problem. My opinion, if you have a classic car, get one. Motor home, NO.
The lastest technology is the AGM or Absorbtion Glass Mat battery. You can read about it here. AGM Absorption Glass Mat Batteries - DC Battery Specialists
These are expensive but COULD be the answer to the big question on the minds of consumers everywhere, Paper? or Plastic?
The Deuceman
DubleDeuce is offline   Reply With Quote
Old 08-25-2009, 09:35 AM   #11
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I recharge our deep cycle with a Honda 2000 when boondocking. That usually will take an hour after an evenings use including DVD viewing. I like the idea of two 6 volts. What would the H-2000 charge time be?
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-26-2009, 04:25 PM   #12
Mexray's Avatar
1978 28' Ambassador
Morada , California
Neil,
I assume you plug the trailer's shore power cable into the Honda genny, when you recharge your batteries...time to recharge your battery system then depends on the rating of your converter/charger, and of course, how far your battery is discharged...
I have a 3-stage charger in our AS, and it's rated at 45 Amps, and probably can 'pump out' about 35 amps in it's bulk charge rate, and so in ONE hour, replace about 35 amp/hours back into our battery bank...at about 80% of full charge, this charger will throttle back to about 'half' it's initial charging rate till the batteries are fully charged...
I guess what I'm trying to say is that it's difficult, at best, to predict the 'how long will it take?" question...the best way to check for a full charge is to take a hydrometer and dip a couple of battery cells to see how far along the recharge process is coming - but nobody wants to go to all that trouble in their RV...so, I, like many others, run the genny till I feel the 3-stage charger has gone into it's 'float mode' - or, as I try to do, check the actual voltage of the battery system, the day after charging (to allow the batteries time to stabilize) to see it the voltage is around 12.65 VDC...if not, I need more genny time....
Old 08-26-2009, 07:23 PM   #13
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
If you use 2 6V batteries and one goes bad you have NO 12V system.
If you use 2 12V batteries and on goes bad you still have one to power your 12V system.
I had to help some folks in the boondocks when one of their 6V died on them.
Jimmini :
AKA : TUMBLEWEED. Just an old deplorable buzzard cling to my guns,& religion ,who loves & served the good old USA.
Cowboys have a way of looking at things a little differently than most folks.
jimmini is offline   Reply With Quote
Old 09-30-2009, 11:26 PM   #14
2003 26' Land Yacht-"Bud"
magwa's Avatar
coarsegold , California
Originally Posted by mello mike View Post
Ah, the age old question: which battery is better? ....snip....
Ayeeee! I'm building a 3600w inverter system in the 26' LY that is completely stand-alone (until I plug in the shore power plug) from the engine bay and house battery system.
Since I have too much time on my hands while I wait for The Boss to retire at the end of October, I researched the "which is better" and which is "value/cost" efficient...and as many other variables as I could calculate.
Bottom Line #1: (for me), I am using two 170Ah sealed 12v, in parallel, which are made attaching a 10A three stage charger that will only be operable when shore power is "humming". They weigh 131 lbs each but are only 11 in tall, ~6" wide and ~ 20" long. Not good for a engine compartment. But there are only two of us and I think we all take too much stuff, anyway. So I was willing to give up the storage space. Right now, I have to wait for the solar. $$$$$
Northstar Battery Company
Bottom Line #2: There's no substitute for experience. I have none. So for anybody who says, "I tried this for (X) years", I respect and appreciate the info.
Bottom Line #2a: Find a battery distributor in your area. A place that does nothing but batteries. Make a friend. They are better to talk to than what you get back by staring at the battery rack at Costco. I've done it all.
Bottom Line #3: There's no right or wrong way...I mean in *choice*....Better wire it correctly. You could *definitely* be wrong on that one.
Bottom Line #4: Waaaaay too many choices for set-up combined with hundreds (or thousands) of different owner use patterns. If a person does not know how many Ah he or she needs, or does not know peak watt surge or continuous watts needed, he or she will soon find out if the system was built "too thin". You'll probably never know if you've overbuilt.
For me, it's onward to test the new batteries and our actual Ah use in real life...Then it's off to concoct the solar charging...(and, also, maybe to figure out how to get a charge from the alt while driving). Then it's off to install an auto-switch to connect the separate system I'm building to existing stock MH set-up. I think unplugging the shore power cord from my new set-up every boondock morning may get old. We'll see. But, right now, it's set up that way to keep everything separate under the "Do No Harm" clause.
magwa is offline   Reply With Quote
Old 10-02-2009, 04:48 PM   #15
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
If you use 2 12V batteries and on goes bad you still have one to power your 12V system..
Good point, can you mix the batteries?
2 6V and 1 12V
or maybe the best bet is 4 6Volts
'77 Sovereign Intl 31' CB
Old 10-02-2009, 04:52 PM   #16
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you don't dry camp why change. Simplest change if you are going to replace batteries due to age would be to go to a type 31 deep cycle, more amp hours without much difference in size and weight.
Old 10-02-2009, 05:40 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
What is the designation for HOUSE BATTERIES?
2004 Excursion 4x4
Old 10-03-2009, 05:48 AM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
2 6V and 1 12V
Old 10-03-2009, 02:54 PM   #19
DubleDeuce's Avatar
Lilburn , Georgia
<<What is the designation for HOUSE BATTERIES?>>
Do you mean what constitutes a house battery in a motorhome or, what technical designation does a house battery have?
Batteries are batteries. Hook 'em up and go. Their output, amps (electricity) and volts (electrical pressure) are not destingushible to the appliances found on a motor home.
The ISSUE of what constitutes a house battey is essentially a simple one, that battery (or batteries) that make up the power source to run the various appliances in the motor home. these can be lights (powered off of the direct batter terminals) that are of the 12V pursuasion) or any of the 110V appliances that are run off of the vehicles power inverter, which draws its power from the "house batteries".
The distinction above is accurate and workable as for as is goes. But in operation the two types of batteries manufactured in the world for the purposes of automotive use are not the same internally. The two types of batteries are "automotive" and deep cycle". House batteries are generally of the deep cycle variety.
In operation, "house use" batteries must sustain long periods of negative discharge and still hold SOME minimal terminal voltage. The inverter will draw down the current (think of current as gallons of gasoline) and convert it to a higher operating voltage. (110V) But eventually, the terminal voltage will fall to a very low point and the effectiveness of the converter to continue to provide minimal voltage (110V) will fail. Many units have an internal automatic "cutoff" switch to prevent heat damage to the converter or appliances due to "low voltage".
As for the batteries themselves, they don't care one way or the other. their internal construction will permit them going all the way to 0 terminal volts (ask any fisherman WHY he carries a paddle in the boat) and when it comes time to recharge them they respond in kind and take the charge. It is worth noting here that even a "deep cycle" battery has only so many charge/discharge cycles in its lifetime and eventually they must be replaced as a group.
Automotive batteries on the other hand have a totally different job function. Their job is to prvide INSTANT and sustained (for a short period of time) amperage at a minimum terminal voltage (usually 9.5V) for the purposes of getting the engine to start in very cold conditions. This requirement can exceed 2000 amps in certain conditions (0 degrees F and a large diesel engine). For this job several batteries are grouped together in paraell to deliver the required amperage.
The type of battery needed for this job MUST have low internal resistance in order to deliver such massive amounts of current and mantain minimal terminal voltage. An automotive rated battery cannot sustain a total discharge (to 0 terminal voltage) and be brought back to life and be expected to last through its normal life time (think of warranty time). Sooner or later, it will fail prematurely.
The difference in the two types of batteries are to be found in their construction. I won't go into great detail here other that to say that one type, deep cycle, are more expensive to produce, than are the automotive type. And, because of the differences, they are not candidates for interchanging into the motorhome system as a function of OEM design.
True, one type can be used in place of the other for a short length of time, but irrepairable damage will come to the automotive type while the deep cycle type might not be able to deliver the "zing" needed on initial start.
THAT is the difference in house batteries. Do NOT look for the designation "House Battery" when shopping for them. You must ask for deep cycle.
The Deuceman
Old 10-03-2009, 03:57 PM   #20
DubleDeuce's Avatar
Lilburn , Georgia
You did not mention the towing vehicle make or model.
The solution to charging the "house batteries" while driving is a simple one. LONG, but simple. Source a constant duty rated (NOT a BOSCH type plug in) power relay (about 60 bucks) and mount it in the engine compartment. Using the RATED power of the vehicles' alternator as a guide, select a wire gauge appropriate to handle the expected charging load. (If your house batteries are very low and you attempt to charge from the towed vehicle, the initial charge rate will be quite high so chose wire gauge accordingly)
Run a separate switch (with control wire) to the power solenoid control terminal. Some power relays are base grounded (ground through the mounting base and have only ONE control terminal) while other power solenoids have TWO control terminals. The two terminals are actually the beginning and the end of a coil of wire. To make this relay work you will need to apply power to one terminal (it does NOT matter which one) and route the other terminal to a ground source. Applying power to the non-grounded terminal will cause the relay to operate and will connect the two large terminal lugs electrically.
Route one of the large terminal lugs to the positive battery terminal (or equivalent) Route the other terminal lug along the vehicle frame to a point meeting at the trailer electrical plug connection. The plug will have to be upgraded to a large capacity 9 position trailer power plug. You can use the center plug for the hot lead into it.
On the trailer side of the connector plug, continue to route the same gauge wire onto the trailer tongue and into the trailer (I guess duct tape and a large 2" hole in the side of the trailer will do)
Once inside the trailer and at the house battery positive lead (it can even be attached at the shore power connection point) connect the alternator lead.
You have a couple of options on how to control the charging system. If you want to throw caution to the wind, just hook up the solenoid control wire to the "HOT in run" position of the key switch. OR, if you want more control, mount a House battery CHARGEON/CHARGE OFF switch on the dashboard between the solenoid control terminal and HOT in run key position. Under NO circumstances should you hook the switch to a constant HOT source as it COULD cause an unintended back feed if you leave the switch on accidentally and a short were to occur. It is also a good idea to fuse the circuit at 100 AMPS to protect against a short circuit.
One more thing, in the solenoid selection process DO NOT accept a solenoid with the control terminals marked in raised letters, such as 'S' and 'I'. This is a solenoid for ignition systems that run on 6Vs (old Chevy/GM pre 1974)and needs a ballast resistor in the circuit. This is NOT a power control solenoid, but rather a starter solenoid and is rated intermittent duty. It will fail with in two hours of installation.
If you or the salesman are unsure about the rating (constant duty or intermittent duty) of the solenoid, just run an Ohm meter across the control terminals (small ones). Anything over 10 Ohms is intermittent duty and should be rejected. The lower the Ohm meter reading, the better.
Now you can haul ass all day and arrive at your new destination in the evening and be all ready for Sunday Night Football on the Plasma screen TV.
The Deuceman
12 volt, 12v
12 Volt Golf Cart Batteries? Phantom Batteries, Univolts, Converters & Inverters 20 11-28-2007 07:29 PM
New Lifeline 6 Volt Batteries lewster Batteries, Univolts, Converters & Inverters 0 04-22-2007 07:24 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 11:58 AM
Two 6 volt batteries on International AS nayl 2002 - 2005 International 9 03-24-2005 09:23 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
