Old 05-31-2014, 08:22 PM   #1
1997 33' Land Yacht
Vanleer , Tennessee
TV Removal
I did not get any help on the Fuse Problem so let me try this problem. I have a 33' land Yacht ant the TV's are old and mostly don't work, Does anyone know how to remove them so they can be replaced. I tried pulling Thanks Doug
Shorthaul is offline   Reply With Quote
Old 06-01-2014, 05:46 PM   #2
1996 33' Land Yacht
RANCHO CORDOVA , California
remove TVs
On my 96 33 ft LY the front TV was stuck with double sided tape across the top. A long sharp knife cut the tape and the TV came out the forward. The rear one was held in just with the frame around the front
zagos24 is offline   Reply With Quote
Old 06-01-2014, 05:48 PM   #3
weirdstuff's Avatar
2018 23' International
San Diego , California
We just removed our front TV from our Interstate. Just involved some screws and bolts. Took 10 minutes, only because we had to find a wrench and screwdriver.
weirdstuff is offline   Reply With Quote
Old 06-03-2014, 06:28 PM   #4
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I replaced both of mine and neither one of them were held in by much more than the face plate. I found their wasn't much room where the existing TV was located so I mounted a larger one off the upper console. If you have a rear bedroom TV like mine was, very small. I completely removed the little padded housing and purchased a swivel mount to accommodate a larger TV. Check out pic's on my photo bucket
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
