Old 07-10-2015, 08:59 PM   #1
comprose's Avatar
1999 31' Land Yacht
Kingston , Washington
TV Connecting
Situation:
1. 1999 Land Yacht 30'
2. Two TVs, color RCA in rear, unknown brand in front.
3. No remotes either set
4. Vehicle has Winegard antenna
5. Vehicle has cable connection; assume connected
6. Would there be a factory-installed splitter servicing the two TVs?
Question is, given the age of the TVs (non-HDTV), can a simple cable connection work?
If not, what needs be done?
Many thanks for any suggestions, remedies, etc., etc.
Mike
comprose is offline   Reply With Quote
Old 07-10-2015, 09:04 PM   #2
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I would assume that the TV's both have a coax connection (CATV jack). If so you may find some places that have standard cable still but for most places you will need a CATV receiver. You may get lucky and the CATV receiver has analog outputs (either composite - the single yellow video cable, SVideo - the cable that looks like an old PS2 mouse, or component - the red blue and green cables. It that case your TV's may have one or all three of those types of connections. The quality of the signal goes up from composite to SVideo to component.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 07-16-2015, 11:48 AM   #3
comprose's Avatar
1999 31' Land Yacht
Thanks. Since both TVs are factory installed I'm not sure how to access the connections. The motor home does have a cable jack near the shore power connection.
Old 07-16-2015, 11:53 AM   #4
Manassas , Virginia
The connections are on the back or side of the TV - I am not entirely sure - but fairly certain there is a splitter from the outside connection to the physical connection on the TV. Can you post pictures of the TV's? The TV's also will have buttons somewhere - check around the edges.
Old 07-18-2015, 10:26 AM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I replaced both my TVs with flat screen models. The one in the front is suspended from the ceiling while the one in the bedroom is on a tilted mounting bracket affixed to the original box. On my unit there was a splitter located behind the driver's side upper trim box near the headliner.
92landyacht is offline   Reply With Quote
Old 07-18-2015, 01:55 PM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I installed new tv's, much lighter, no more dangling or in the way convertor box all around better situation. And getting the same brand, remote works for either.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Connecting a Cable Modem Crusty Audio, Video & TV 8 04-19-2017 03:23 PM
Connecting the electrical supply adonh Electrical - Systems, Generators, Batteries & Solar 4 11-24-2007 07:56 PM
Oil in the propane line and a connecting hose dbensen LP Gas, Piping, Tanks & Regulators 2 10-20-2005 07:50 AM
Connecting to Electricity ssolid Electrical - Systems, Generators, Batteries & Solar 22 02-12-2004 08:09 AM
connecting 110V system to inverter Cruiser Electrical - Systems, Generators, Batteries & Solar 4 07-16-2003 09:46 PM
