Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 11-11-2013, 08:58 AM   #1
1995 34' Land Yacht LE
elkton , Maryland
Towing dilemma...
Hello,
We're looking into towing one of our vehicles with our 1995 Land Yacht. It says the towing capacity is 2000lbs. First problem, our 2000 Ford Explorer 4x4 can only be towed all wheels off the ground...which def places it out of weight range. Our 2010 Honda Odessey minivan can be pulled 2 wheels off the ground or all wheels with a tow bar. If we pull using a tow bar..I assume that means the total weight of the van 5000lbs+ will be on the motorhome? So if we pull using a tow dolly with 2 wheels off the ground, does that mean half the weight of the van is being towed?
I just want to be safe and there doesn't seem to be a clear cut answer.
Any suggestions where I can get help?
Dorothy in MD
dotnang is offline   Reply With Quote
Old 11-11-2013, 09:15 AM   #2
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Originally Posted by dotnang View Post
Hello,
Dorothy in MD
Either I'm confused or you're confused along the way here:
When you say a towbar, I assume you mean that the vehicle has all 4 tires on the road, and a towbar on a bracket that hinges to allow the bar to go up and down freely, which often happens when you are towing. If that is what you mean, then there would be close to zero weight (just half the weight of the bar) on the motor home in a vertical sense (i.e. tongue weight). However, IMHO 5000 lbs would still be too much for your LY. It's a long distance from you rear axle to the towball, and 5000 lb is a lot of weight with a lot of leverage on the chassis, in a lateral, that is side to side, direction. I am sure that others will share opinions that differ from mine, but I feel that a towed vehicle weighing somewhere near 3000 lbs would be the maximum safe weight to tow without having your chassis/tow hitch sturdily reinforced by someone who knows what they are doing and is willing to assume the liability for doing the work. I have seen towed vehicles thrashing around behind a motor home in the past, putting huge strain on the structure. If you look at a bunch of motor homes of the lighter weight van chassis type (like ours) you will often see that they are drooped behind the tag axle, and the cladding shows signs of warping and flexing, and this is from towing too heavy.
As to a tow dolly, you then have the whole tongue weight issue, and vertical leverage on the MH come into play, as well as the lateral forces. With a tow dolly, about all you could safely tow would be a Smart Car......
Punch is offline   Reply With Quote
Old 11-11-2013, 09:26 AM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
If one tows a a four wheeled vehicle with all four tires on the ground, no weight whatsoever is placed on the towing vehicle.
The tow bar apparatus is hinged at the connection point on the towed car, so no weight can be transferred to the motorhome.
As far as sway and lateral movement, the steer axle of the towed vehicle is left unlocked, to allow the wheels to follow the path of the motorhome.
I don't see that the towed car can exert much force on the motorhome.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 11-11-2013, 10:59 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would take towing capacity to mean that is the maximum weight of the towed car plus trailer or dolly. You need a Miata or pt crusier or VW or something small that can be towed with all 4 wheels on the ground.
Old 11-11-2013, 10:59 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
No matter what you do, you are still towing all the weight of the vehicle
With different approaches you are only changing the amount of weight the motorhome is carrying.
With a towbar you are not carrying any weight. With a dolly ( or trailer) there will be some tongue weight.
Either vehicle exceeds the tow rating of the motorhome by quite a bit.
If you tow with a dolly you then have to find a place to park it as well as the towed vehicle. Most people I know give up the dolly approach fairly quickly and get a vehicle that can be towed 4 down.
I have seen larger ( 1/2 ton pickups) towed by Airstream MH but don't know if they were ignoring the tow ratings or not
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 11-11-2013, 11:00 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
By putting two wheels on a two dolly you have not decreased the tow weight. In fact, you have increased the tow weight by the weight of the dolly.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 11-12-2013, 04:40 AM   #7
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Dorothy didn't say which Land Yacht she was towing with. I think the gas models have a lower tow rating than the diesel pushers, her 2000 lbs must mean it's gas.
Ours is a diesel pusher with a tremendous hitch arrangement that hooks to the frame and goes way up beside the radiator. We tow close to 5000 lbs with a car trailer (with 4 wheel brakes) and it does just fine. With our "toad" which is a Saturn Vue, we're at 3500 and hardly notice it. (But it's equiped with it's own air brake)
So far all the advice has been good.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 11-12-2013, 06:22 AM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Tow dollies have a low tongue weight even when loaded. I saw a guy lift a tow dolly off the ball with a car loaded on it, one handed. The front wheels of the car are over the wheels on the dolly, so not much tongue weight.
That said, I've come to the conclusion that tow dollies are the worst option. If you're always going to use the same vehicle, a tow bar is better. Putting the vehicle on a full car trailer is by far the best option (but now you have to watch tongue weight). I rented a U-Haul full trailer to move my Cougar a few months back, and it was night and day compared to having the Cougar on a dolly - they just tow that much better, and you can back up.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-12-2013, 08:22 AM   #9
Rivet Loser
Punch's Avatar
When you are braking, the tow dolly has a LOT of tongue weight. Funny thing that!
Old 11-12-2013, 05:13 PM   #10
elkton , Maryland
ok--obviously I'm clueless when it comes to towing! LOL Thanks for all the replies. We're a family of five so towing a small car that would not carry us is no good. The tow bar seems the way to go if I feel safe enough. Now to figure out if our 2000 ford explorer with AWD can be towed all 4 wheels down. Ford dealer couldn't give us a straight answer and the manual is misleading. I Love my airstream motorhome but thinking in the future the way to go may be a travel trailer.
And yes, my rig is gas. thx again!
Old 11-19-2013, 05:35 PM   #11
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Lafayette , Louisiana
We tow a 4000lb Taurus X with the 6sd automatic transmission four wheels down with a blue ox tow bar assembly. We have put several thousand miles on our Gas 454 LY and my wife (who does all the driving) says apart from the camera she hardly knows it is back there. You will want to use a digital braking system for the TOAD as well. A Banks system (exhaust headers, tuned exhaust and cold air induction) will give you a bit more "grunt" pull the extra weight.
jrkeef is offline   Reply With Quote
Old 11-19-2013, 07:51 PM   #12
1988 32' Excella
Robbinsville , New Jersey
You know your 2000 ford explorer with AWD weighs more then 4000lbs and is more then double your tow capacity.
Old 11-19-2013, 08:57 PM   #13
Rivet Loser
Punch's Avatar
Wazbro, what you say is just going to fall on deaf ears, I'm afraid. There are a lot of people who tow heavy vehicles and trailers behind their Airstream Classics and LY's. I went to look at an '88 345 that had towed a 4500 lb vehicle behind it for thousands of miles, and you could clearly see distortion of the body behind the tag axle. But common sense ain't gonna win if Airstream's own guidelines are being ignored, let's face it.
Old 11-20-2013, 11:59 AM   #14
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
My deaf ears were pricked. My 2000 30 LY maxim towing weight, according to A/S, is 4000lbs. My Taurus X weighs 4012. My hitch is rated at 5000 pounds and my Blue Ox tow assembly is rated at 10,000 pounds. Using the SMI Stay-in-play duo proportional towed car brake system I stand by my "common sense" contribution to this thread.
Old 11-20-2013, 02:44 PM   #15
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I can pull my Ford Ranger pickup automatic at 4000 pounds but AS doesn't take as long in the low gears when I am pulling my 2500 pound Honda Fit automatic. The ford I had to install a transmission disconnect while the Fit doesn't require anything. I would recommend fixing the MH chassis for whatever you choose, the light weight Smart car wouldn't handle the passenger load.
Old 11-27-2013, 08:41 AM   #16
2000 31' Land Yacht
Fort Erie , Ontario
The other issue no one is talking about is the ability to stop! The P32 chassis breaks are marginal at best (even when not towing, IMHO) that an auxiliary breaking system is a must. Check your State regs on requirements.
My rig is similar to Jerry's in that I have the banks system in for the pull power the blu ox towbar and the SMI stay in play duo for the towed. I'm pulling a Toyota Matrix 4 down that weighs in at 1830 Kg that's 4034.39 #, so am a bit over and had no problems going thru the Rockies past summer.
Steve
is.chowa is offline   Reply With Quote
Old 11-27-2013, 08:48 AM   #17
2000 31' Land Yacht
Fort Erie , Ontario
Just an afterthought: Make sure you have something to protect the paint on the towed when towing. BTW, the toyota can squeeze in 3+2.
Steve
Old 11-28-2013, 05:42 PM   #18
2000 31' Excella
Ontario , Canada
Originally Posted by is.chowa View Post
The other issue no one is talking about is the ability to stop! The P32 chassis breaks are marginal at best (even when not towing, IMHO) that an auxiliary breaking system is a must. Steve
Couldn't agree more Steve.
I have the 2005 LY 30 with the 8.1. It feels as though it could go uphill anywhere. But stopping is another issue. I have auxilliary braking on the 2012 SRX 4300 lbs (using BlueOx) that I tow. Without the auxilliary braking, it would be insane.
woodytwo is offline   Reply With Quote
Old 12-03-2013, 05:18 AM   #19
1992 35' Airstream 350
Ennis , Texas
towing...
Our 1992 Airstream classic 350LE has no problems towing the following:
We are towing our 2012 Ford Escape v6 All wheel drive, wheels down in neutral. We have to go thru the gears every 5 hours which means while stopped we shift gears [while running the engine] thru all P - R - N - D - D2 for 5 minutes to lubricate the transmission. We have done this for 18 months without any problem at this time. Ford approves this procedure and the vehicle is about 3600 lbs.
We also have a 2013 Smart for 2. It weights about 1800 lb. We tow it 4 wheels down and just put the transmission in neutral.
Chief
1969fowler is offline   Reply With Quote
Old 12-04-2013, 11:19 AM   #20
2000 31' Excella
Ontario , Canada
OK I agree. But I assume that your hitch like mine is rated at 500 lbs not 5000 lbs. And the weight of your Taurus dry is 4012 lbs. If you then carry stuff in your car you need to add that weight. Tank full of gas adds 150 lbs or so. Blue Ox tow gear adds ???. My guess is that you are closer to 4400 lbs which is what I pull. I also use the Blue Ox tow assembly and use the US Gear breaking system in the toad. To me this a safe towing package and a safe towing weight. As someone else said that except for the rear camera, I don't know that it is there going down the hiway.
As an aside which will rankle some people, the towing weight is not set by the engineers alone. It is set by the lawyers and marketing guys based on the knowledge that a lot of owners will tow more than the manual recommends and also what towing capacity they need to advertise to sell the MHs. It also doesn't take into account whatever mods have been made to the MH hitch ie reinforcing.
