Old 05-29-2009, 03:06 PM   #1
1992 36' Land Yacht
hubbardston , Massachusetts
to buff or not to buff
1992 36ft airstream motorhome
exterior needs a little tlc,,,
is it gel coated fiberglass???
is waxing enough??
can you or should you buff the finish??????????
confused
kevin
kepko is offline   Reply With Quote
Old 05-30-2009, 04:24 AM   #2
harold1946's Avatar
2005 30' Land Yacht 30 SL
Surprise , Arizona
Kevin; Not sure about that model year but if you go to Airstreams website and send them an e-mail they can tell you.
Ours is gel-coated fiberglass with Sherman Williams automotive paint and then clearcoat..I found the paint codes sticker inside the closet. I use 303 aerospace protectant and then buff. So far I am very happy with the results.
harold1946 is offline   Reply With Quote
Old 05-31-2009, 05:02 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
is waxing enough??
confused
kevin
My 1993 LY MH was badly oxidized gelcoat, waxing will not remove this. You need to use a product to remove the oxidation before waxing. I used a product called Turbo Cut by Wizard automotive product. There is acutally a 3 step system, I just used this to remove the oxidation. It's a lot of hand work, but the results were very good. The front and rear caps are acrylic & not gel coat - it even did an excellent jobs on these.
Randy
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Buff Buff Buff!! tjj's63 Cleaning, Stripping & Polishing 3 06-01-2005 07:32 AM
