Old 10-09-2019, 11:49 AM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
thermopane window seals
How much trouble is it to reseal the thermopane windows if the seal has moved into the viewing area of the window?
A do it yourself job or a glass shop?
2004 Excursion 4x4
Old 10-09-2019, 11:53 AM   #2
1981 31' Excella II
New Market , Alabama
A good bit of trouble. Some of the early 70's trailers had removable inner panes but most require the window frame be removed then the frame pulled apart at the seam. Lots of work. Some just remove inner pane and shim the frame to hold the outside pane in.
Good luck
Perry
Old 10-09-2019, 11:55 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
No idea about this specific window. On a residential window, it's a "replace the whole thing" process. ( = there really isn't a functional repair. ). The big deal there is the window fogging rather than the seal moving.
Old 10-09-2019, 12:12 PM   #4
HowieE's Avatar
Images: 12
I should update my question. My question is for a 2005 Land Yacht motor home. From pictures the seal appears to be a foam spacer rather than a hermetic seal.
2004 Excursion 4x4
Old 10-09-2019, 06:48 PM   #5
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
We have the same problem in our 1999 Land Yacht Diesel.
What Iíve found out is the window unit must be removed from the motor home. Then the window unit can be disassembled. Drying between panes when reassembling is the problem.
Iím going to try in the spring.
Robfike is offline   Reply With Quote
Old 10-10-2019, 05:41 AM   #6
Robfike's Avatar
Spencer , Indiana
I found this company that has the option of a new replacement window.
I may possibly go this route for my cockpit side windows.
http://segiwindows.com/?nr=0
Old 10-13-2019, 01:53 PM   #7
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Do a search on the internet you will companies they do the repair and I believe there is a diy on YouTube
I had mine done at rvfogdr .com
Good luck
PSchw is offline   Reply With Quote
Cutter thermopane window seal johnleidy Airstream Motorhome Forums 2 08-19-2015 10:23 AM
Fogged Thermopane Window Fix! Donald Windows & Screens 17 06-22-2010 08:16 AM
Thermopane Window Redbird Windows & Screens 2 05-21-2007 02:04 PM
thermopane windows art 1974 - 1979 Sovereign 2 12-27-2002 05:48 PM
thermopane glass Chas Windows & Screens 1 12-27-2002 04:52 PM
