Old 09-01-2015, 04:30 PM   #1
1998 31' Land Yacht
Lake Odessa , Michigan
Test Panel
I am having issues with the readings I get for both the gray water and black water tank readings when I test them. They are reading 50% full when empty? Are these sending units able to be replaced?
btuinstra is offline   Reply With Quote
Old 09-01-2015, 04:48 PM   #2
ericpeltier's Avatar
Superior , Colorado
They get covered in gunk, and become inaccurate. Check out the SeeLevel for an accurate replacement.
ericpeltier is offline   Reply With Quote
Old 09-01-2015, 04:54 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out the latest issue of Airstream Life, excellent article on calibration of the unit.
MICHAEL
Old 09-16-2015, 06:33 PM   #4
kenajen's Avatar
1972 23' Safari
2005 30' Land Yacht 30 SL
Miamisburg , Ohio
What year and model do you have. My 2005 Land Yacht 30SL has screw in sensors with RJ 11 connections. They are not protected from moisture and are placed behind the drivers side rear wheels. My gray water sensor got wet and they short out immediately like a phone jack. The short causes the panel to report a full or partially full state when the tank was empty.
kenajen is offline   Reply With Quote
Old 09-17-2015, 04:41 AM   #5
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I found my tank level indicators to be of little use on my 2005 Land Yacht gas motorhome.
Airstream12557 is offline   Reply With Quote
Old 09-17-2015, 03:28 PM   #6
Palo Alto , California
We have a 1995 LandYacht Wide Body Diesel. We had the exact same problem with the gray and black tanks reading partially full right after dumping. We bought a backflush device (Flush King) at Camping World and used it according to the directions and they both read empty now on the Test Panel.
lesvoyageurs is offline   Reply With Quote
Old 09-17-2015, 11:12 PM   #7
TerraYacht's Avatar
Castro Valley , California
I had bought a replacement sensor for my grey tank and when I pulled it out to replace it I found it all gunked up. Cleaning it restored it to proper operation, but I'm not sure that will be the case if/when I look for the fresh water sensor to get it working right.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 09-17-2015, 11:49 PM   #8
Our fresh water sensor seems to be working ok. Would be interested in knowing what you find if/when you investivate it.
test panel rochar3 Electrical - Systems, Generators, Batteries & Solar 2 06-29-2015 01:22 PM
Polishing a new panel to match an Alclad panel 66replica Cleaning, Stripping & Polishing 4 09-13-2014 12:29 PM
Test button on converter panel. flyslinger General Repair Forum 4 07-29-2012 02:01 PM
Test hex Our Community 8 10-17-2002 04:20 PM
