Old 06-07-2012, 08:13 PM   #1
1998 31' Land Yacht
Mt. Pleasat , South Carolina
Stiff shift
The gearshift lever on the steering wheel is so stiff i use two hands and a lot
of muscle to shift thru P-R-N-D. This is a 1998 chevy 454 land yacht auto trans.The chevy dealer said engine heat caused the plastic sheath on the wire linkage from steering column to transmission to bind. I was told the link was no longer made Help please.
bizzie is offline   Reply With Quote
Old 06-10-2012, 07:32 AM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
The shifting lever on my 1993 LY was doing the same thing. What helped was spraying a penetrating lubicant on end of wire linkage cable at transmission and having someone continually shifting while spray was being applied, it eventually freed up. I did this a couple years ago and it has been fine. Also re-coated it with lithium grease.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 06-10-2012, 08:50 AM   #3
1998 31' Land Yacht
Many thanks for a simple solution. I never found the cable linkage on the internet. I now keep spray oil and lithium grease onboard. Sincerely, Bizzie
Old 06-10-2012, 10:22 AM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Motorcycle shops have a lube system designed for control cables. It consists of an aluminum (aluminium) block with a molded rubber liner that fits over the cable end and a spray can of lubricant that attaches to it to force lube up the sheath along the cable. I use this set up to lubricate transmission kick-down cables on cars when they get sticky. Here is one example:
Cable Care Kit Power Injection System - Protect All
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-11-2012, 06:55 AM   #5
1998 31' Land Yacht
Sometimes the simple solution is just right. Many thanks. BIzzie
