Old 06-03-2016, 06:30 PM   #1
Cody winkler's Avatar
1994 33' Land Yacht
Selma , Texas
Sound from differential
Every time I put it in drive it makes a ping like sound from the differential, I have no clue
Cody winkler is offline   Reply With Quote
Old 06-03-2016, 07:00 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The first place I would look is for a worn u joint in the drive shaft.
CRH is offline   Reply With Quote
Old 06-03-2016, 07:28 PM   #3
1973 31' Sovereign
Middletown , California
Probably the drive shaft ringing as the slack in the drive is taken up. Does it happen when going back and forth from reverse to drive when standing still? Could be a normal sound for that vehicle. Could also be sign of excessive wear of U joints and splines, check to see if you can lube anything on the driveshaft. Could be sign of excessive wear in rear axle parts but if you roll down the road quietly you should be OK. Probable trouble if you hear a growling sound that changes when you go between power and coast, or changes when weaving side to side.
ijustlee is offline   Reply With Quote
Old 06-03-2016, 07:29 PM   #4
1994 33' Land Yacht
Selma , Texas
I crawled underneath and wiggled everything but the u-joints all looked good.
Old 06-03-2016, 07:31 PM   #5
1994 33' Land Yacht
Selma , Texas
Okay thank you I greased everything, it just started a few days ago and only happens when still. Luckily there is no howling which makes me to believe that the differential is okay
Old 06-03-2016, 11:22 PM   #6
2007 22' International CCD
Verify that the differential has enough gear oil in it. Verify the right viscosity and condition. Don't ask how I found this out the hard way....
Old 06-04-2016, 12:13 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Post 2 had the right answer. (95%)
One or both of the u-joints are worn.
Not to say that it wont last a while longer, maybe a long while, and maybe not so long.
It is very hard to see this kind of looseness in a u-joint by shaking or prying on it, it can be found by getting under the vehicle while someone that you TRUST A LOT sits in the drivers seat with his foot firmly on the brake while shifting from reverse to drive repeatedly.
I would NOT do this with a vehicle on ramps, stands, or a jack.
Superat stultitia.
Old 06-04-2016, 07:27 PM   #8
1994 33' Land Yacht
Selma , Texas
It was a u-joint, glad it's a easy fix
Differential maintenance tpi Tow Vehicles 10 07-18-2011 04:44 PM
Rear Differential Problem?? Help! FLYNCLD Tow Vehicles 31 04-19-2010 12:04 PM
Buzzing sound from sound system, walking on floor makes it stop. foqus Electrical - Systems, Generators, Batteries & Solar 9 08-24-2009 09:22 PM
Temperature Differential Expected JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-28-2005 11:48 AM
split differential or locking differential cindy foxx Tow Vehicles 6 01-22-2003 08:48 PM
