Old 12-17-2007, 12:38 PM   #1
harold1946's Avatar
2005 30' Land Yacht 30 SL
Surprise , Arizona
Question Slide out window awning
Does anyone know if a window awning can be installed on the slide out of an 2005 AS 30' LY mh ? All of the windows have A&E awnings except the slide out. Is there enough room for installation beneth the slide out awning.
harold1946 is offline   Reply With Quote
Old 12-17-2007, 02:32 PM   #2
Naples , Florida
Hi Harold,
It depends on the 'freeboard' or distance between the top of the window and the top of the slide. I've installed awnings in a lot of strange places (I won't list any details ) but it should not be a problem.
If you have an trouble locating a matching awning, let me know as I am a dealer/installer for all of the major awning companies, including A & E.
lewster
Old 12-18-2007, 06:21 AM   #3
harold1946's Avatar
Surprise , Arizona
I dont know if this is a good idea or not. We will be in Phoenix Az. for at least 2 months this summer. [ I know, bad timing ] And thought it would be good to shade that window also.
Old 12-18-2007, 03:47 PM   #4
Naples , Florida
Harold,
Many larger MoHos use the type of arrangement that you are talking about ifthe don't already have an 'Omega II' slide topper from Carefree of Coloado. This awning not only covers the slide, but gan be manually extended to cover the window as well.
I've seen many that use a separte window awning in tandem with the slide cover.
lewster
Old 12-18-2007, 06:50 PM   #5
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Harold,
Can't imagine this would be a problem. Our 2004 30' Classic came from the factory with a zip dee awning that covers the slide and can be further extended to shade the window.
fltlevel510 is offline   Reply With Quote
Old 12-28-2007, 06:43 AM   #6
harold1946's Avatar
Surprise , Arizona
It looks like I'll have to go with the zip dee, not enough room for mounting under the slide cover. Found a local dealer that has been very helpfull. Thanks for the help.
Front Window 'Awning' Grand Master Awnings 1 10-31-2007 09:36 PM
Need Window Awning Brackets RBolton Awnings 3 08-01-2007 12:13 PM
Installing a new Zip Dee window awning Qs? Antique Pedaler Awnings 1 06-27-2007 05:06 PM
Rear window awning azflycaster Awnings 10 03-22-2006 06:01 AM
How wide is a rear window awning? RichardT Our Community 3 01-31-2005 12:14 PM
