Old 08-13-2013, 11:28 PM   #1
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Silver lettering
I need to replace a couple of the stick-on letters on front and rear of my `94 LY 34 foot. They are silver with a black edge, seem to be made of a thick transparent plastic material, and about 3" tall. Are these still available?
Sorry about the bad picture.
Punch is offline   Reply With Quote
Old 08-14-2013, 06:17 AM   #2
dznf0g's Avatar
Oswego , Illinois
contact AS directly, they have many different ones in the AS store. However, you will likely have to replace the whole word...not just a couple letters.
-Rich-
Old 08-14-2013, 09:55 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
You could check with your local lettering shops. They can make lettering to match, duplicating size an shape of letters. Probably a lot cheaper than AS. Just a thought.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 08-15-2013, 06:01 AM   #4
1981 31' Excella II
New Market , Alabama
You can get some decal material and cut some out with a razor blade or Xacto Knife. The decal shops have printers that can make any shape or letter you want. They put a sheet of decal material in the printer and it cuts the shapes out.
Perry
Old 08-15-2013, 07:08 AM   #5
Rivet Loser
Punch's Avatar
Thanks for suggestions. The problem with getting decal material is that the letters are about 1/4" or 5/16" thick transparent flexible plastic. I'd make my own if I could think of a source for the thick plastic, since the black margin and silver back would be easy. I shall investigate AS and custom. If anyone has a LY they are parting out, I think the letters could be razored off easily, and I'll happily buy it/them. I really mostly need one "R".
Old 08-15-2013, 07:57 AM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream sells them in strips with the complete wording on them. It's sort of a double stick method where you peal the back, the front sticky holds the letters together to keep them straight. Once you place them down and seat them you peal off the front tape. It's pretty cool.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-16-2013, 01:57 PM   #7
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
Jack
Are these the three dimensional letters or a two dimensional decal?
When we were at JC a couple of months ago, all I saw where the two dimensional decals.
BarnacleBill is offline   Reply With Quote
Old 08-17-2013, 04:26 AM   #8
jcanavera's Avatar
Fenton , Missouri
Images: 143
They were the exact same same lettering that they use in the factory. I think others here on the forum have ordered them.
Jack Canavera
STL Mo.
AIR #56
