Old 07-02-2016, 06:26 PM   #1
1996 30' Land Yacht
Benson , Arizona
Sikaflex 221 on End Caps?
96 LY 30.
After spending the better part of today peeling/cutting of multiple layers of Dicor self leveling from the rear end cap, I'm about ready to pull the trim to clean out the old ??? under the trim (on the front it was like white butyl, but tougher), seal the void with Sikaflex 221, and put the trim back on.
Once back on, can Sikaflex 221 be used (successfully) as a bead seal? They do not make it in a self leveling. Rather not use the Dicor self leveling, as every bead on this coach I have pulled has been cracked and repaired with piling up more by previous owners.
When I put the trim on, it will be filled with the 221 before install - unlike the AS factory install. So I think a bead from the trim to the fiberglass roof would be sufficient. The trim is about 1/4" high, so it would be "stuck" to the deck in about a 3/8" area.
Did a search, and while there are more multiple threads on the Sikaflex use, none with details on the End Caps.
pago cruiser is offline   Reply With Quote
No drill solar panel mounts SikaFlex-221 or 3M THB tape? cdufault Electrical - Systems, Generators, Batteries & Solar 18 12-17-2018 05:03 PM
Sikaflex 221 & Vulkem Questions Hans627 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-27-2016 08:22 PM
Is there anyone who uses Trempro 636 & Sikaflex 221 on a 70's AS bennyg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-29-2011 09:16 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 01:22 PM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 06:37 PM
