Old 12-19-2008, 08:13 PM   #1
2002 31' Land Yacht 30
Auburn , California
shock mounts
I just noticed i broke one the rear shocks and after taking the piece off the mount on top is broken in two places where it is riveted to the frame. Does anybody know how to replace those rivets or is it better to just bolt back on the mount with stainless bolts? i am in a parking lot and do not have access to many rivet tools or air guns. Plus does anyone know where to get those big rivets that are needed?
Thanks Tim
tebone is offline   Reply With Quote
Old 12-19-2008, 08:15 PM   #2
Auburn , California
Sorry it is a 2002 landyaht with bilstein shocks
The mounts look like they were an after thought because the other one looks bent as well!!!
Old 12-19-2008, 09:05 PM   #3
The shock mounts are studs that are welded in place.
The incorrect shocks that are on your trailer is the cause of the problem.
Old 12-19-2008, 09:17 PM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Ok
I personally would take it to a truck repair facility that has chassis repair facilities. If you are in a parking lot you probably don't have what is needed for this type of repair.
There is a replacement shock mount that bolts in. Check this out this page they have two types. Speedway Motors - Product Summary
What chassis are we talking about? Length?
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-20-2008, 03:19 AM   #5
Lothlorian's Avatar
Loganville , Georgia
If they are incorrect shocks then what are the correct shocks?
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
am solar mounts and kyocera panels Yak dad Generators & Solar Power 2 06-21-2008 09:21 AM
64 Globetrotter shock mounts bad? koltys Shocks 1 08-13-2007 07:48 PM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 09:08 PM
CB Antenna Bracket Mounts Dwight Phone, CB & Ham Radio 1 01-26-2004 02:07 PM
'70s era TV stands/mounts Safari Tim Interior Restoration Forum 0 07-05-2003 05:24 PM
